I just picked up a used Canon 10-22 with a hood, but the hood (EW-83E) seems awfully loose. I can jostle it around about 1-2mm in each direction when mounted.
Anybody else's hood like this, or is this normal?
Clovis Member 33 posts Joined Dec 2007 More info | Apr 29, 2008 21:55 | #1 I just picked up a used Canon 10-22 with a hood, but the hood (EW-83E) seems awfully loose. I can jostle it around about 1-2mm in each direction when mounted.
gasrocks Cream of the Crop 13,432 posts Likes: 2 Joined Mar 2005 Location: Portage, Wisconsin USA More info | Apr 29, 2008 22:04 | #2 Assuming you are a male in the USA, I'm suprized that you haven't thought of duct tape as a solution yet. A little play never hurt anyone. GEAR LIST
doidinho Goldmember 3,352 posts Likes: 23 Joined Aug 2007 Location: Kenmore, Washington More info | Apr 29, 2008 22:05 | #3 |
Apr 29, 2008 22:08 | #4 gasrocks wrote in post #5431108 Assuming you are a male in the USA, I'm suprized that you haven't thought of duct tape as a solution yet. A little play never hurt anyone. I was just thinking of putting some tape on the hood to make the connection tighter. doidinho wrote in post #5431118 Shouldn't move at all once its on. Check for a broken edge on the lens and hood (hopefully on the hood). I don't see any damage to the hood or the lens.
Marcy Goldmember 1,752 posts Likes: 25 Joined Aug 2007 Location: on the road in an RV More info | Apr 29, 2008 22:18 | #5 mine is very tight - almost too tight - hard to get off sometimes
liquefied Goldmember 1,160 posts Joined Oct 2006 More info | Apr 29, 2008 22:55 | #6 It's plastic. Plastic flexes and bends. As long as it doesn't fall off, who cares?
JustBe Goldmember 1,449 posts Joined Jun 2006 Location: Seattle area More info | Mine is perfectly tight.
brados1983 Hatchling 1 post Joined Aug 2006 Location: Gold Coast AUSTRALIA More info | Apr 30, 2008 06:13 | #8 is it an after-market hood??
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Apr 30, 2008 06:22 | #9 Clovis wrote in post #5431042 I just picked up a used Canon 10-22 with a hood, but the hood (EW-83E) seems awfully loose. I can jostle it around about 1-2mm in each direction when mounted. Anybody else's hood like this, or is this normal? Being loose is not normal, and it reduces the benefit of the hood. One of the things a hood can do for you is act as a "bumper" to ward off the effect of impact against things around you. Skip Douglas
Apr 30, 2008 14:31 | #10 SkipD wrote in post #5432737 Being loose is not normal, and it reduces the benefit of the hood. One of the things a hood can do for you is act as a "bumper" to ward off the effect of impact against things around you. I would suggest that you purchase a NEW hood, not one somebody got rid of because they wore its mounting threads out or messed up by modifying the mounting threads. That makes sense, I guess the mounting thread on the hood has been worn out and isn't gripping the lens properly. I guess I'll have to pickup a new hood.
DoubleNegative *sniffles* 10,533 posts Likes: 11 Joined Mar 2006 Location: New York, USA More info | Apr 30, 2008 15:50 | #11 I had a lens hood that was a little loose for my taste (IIRC, it was on the 24-70mm). I used a needle nose plier and gently dimpled the bayonet flange on the hood (not the lens!) and it's been tight ever since. La Vida Leica!
| Latest registered member is Frankie Frankenberry 1040 guests, 117 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
