Now that the 40d has been out for seven months, have any of the early adopters developed an opinion on whether the sensor shaker does any good?
Ralpho Member 161 posts Likes: 3 Joined Aug 2005 Location: St. Louis, Michigan More info | Apr 30, 2008 04:27 | #1 Now that the 40d has been out for seven months, have any of the early adopters developed an opinion on whether the sensor shaker does any good?
jerrybaxter Member 50 posts Joined Mar 2008 Location: Carrollton,Texas More info | Apr 30, 2008 05:08 | #2 Seems to work very well for me. Had mine 6 months and only needed to "blow" a very sticky dust bunny out.
timnosenzo Cream of the Crop 8,833 posts Likes: 14 Joined Sep 2005 Location: CT More info | Apr 30, 2008 05:22 | #3 It works, I don't think it will eliminate cleanings, but it will extend the amount of time between them. connecticut wedding photographer
evandavies Goldmember 1,436 posts Likes: 1 Joined Feb 2006 More info | It certainly works. E:¬D
RedDot Senior Member 627 posts Joined Feb 2008 Location: Trapped Inside the Penta-prism More info | Apr 30, 2008 06:57 | #5 just thinking, if the camera can shake off dust inside it, where do you think that dust goes? I tried to write my signature, but my pen ran out and I put a big scratch on my monitor
Apr 30, 2008 06:58 | #6 Ralpho, Sony A6400, A6500, Apeman A80, & a bunch of Lenses.............
Tsmith Formerly known as Bluedog_XT 10,429 posts Likes: 26 Joined Jul 2005 Location: South_the 601 More info | Apr 30, 2008 07:10 | #7 I was very skeptical of it but will say after 1200 images and many a lens swap I've got one very minor speck @ f/22 that came on it brand new out of the box. I've used the feature about 4 times since getting the camera and that one spot is all thats visible and you gotta look close to find it. Haven't use my Rocket Blower on it yet or ordered any Eclipse 2 fluid. evandavies wrote in post #5432604 By contrast my old 30D with the same general usage would need a wet clean every couple of months. kinda my same experience too but not as often.
ipschoser1 Senior Member 497 posts Joined May 2007 More info | Permanent banMy 40D dust sytem mimics the experiences I have had with the XTi. The system works pretty darn well for keeping most trash away. You will need an occasional cleaning or dust map, just not nearly as often as with older equipment. Well done Canon! http://www.flickr.com/photos/district_history_fan/
elader Goldmember 2,374 posts Likes: 1 Joined Nov 2005 Location: Maryland More info | Apr 30, 2008 07:44 | #9 I seem to have a sopt on my sensor - witht he 20D by this much time I would have had to clean it 10X - so yes, it works. Eric
evandavies Goldmember 1,436 posts Likes: 1 Joined Feb 2006 More info | Apr 30, 2008 09:27 | #10 Red Dot wrote in post #5432857 just thinking, if the camera can shake off dust inside it, where do you think that dust goes? It falls onto an adhesive strip at the bottom of the mirror box. Thats another reason why a blow in there could make some airborne again. E:¬D
wrussi Senior Member 788 posts Likes: 2 Joined Dec 2007 Location: miramar FL More info | i had it on my xti now on the 40d works pretty darn good. u still have to be careful when changing lenses and what not. Gear List
apersson850 Obviously it's a good thing More info | I saw dust after two days of using the 40D. The automatic cleaning didn't shake it off, but when invoking it manually a couple of times (when you do that, it will release the shutter as well, to give a little more "shake"), that took care of the problem. Anders
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Apr 30, 2008 09:51 | #13 I think the situation varies user to user! I had my 20D for 3 years, and only once had to resort to cleaning the sensor. So if I own my 40D for 3 years and never have to clean in that time, I guess I can speculate that it helped! You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
No need to clean my 40D after 6,000 exposures. Digital EOS 90D Canon: EF 50mm f/1.8 II, EF 50mm f/2.5 Compact Macro, Life-Size Converter EF Tamron: SP 17-50mm f/2.8 DiII, 18-400mm f/3.5-6.3 DiII VC HLD, SP 150-600 f/5-6.3 Di VC USD G2, SP 70-200 f/2.8 Di VC USD, 10-24mm f/3.5-4.5 DiII VC HLD Sigma: 30mm f/1.4 DC Art Rokinon: 8mm f/3.5 AS IF UMC
| Latest registered member is Mihai Bucur 1205 guests, 129 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
