Thread started 01 May 2008 (Thursday) 15:11
70-200 f/4 L tripod collar.......
snatiep
May 01, 2008 15:11 |  #1
Hello Everyone,
I'm about to purchase a Manfrotto 055XPROB and 488 RC2 ball head. Do I need a tripod collar to hold my 30D and 70-200 f/4 L (non-IS)?
Thanks!
Nate
Dorman
Joined Feb 2006
May 01, 2008 15:17 |  #2
I've never felt the need for the tripod collar - different story on the 70-200 F/2.8
hughps
May 01, 2008 15:29 |  #3
I bought a knockoff collar from eBay and have been very pleased with it. It's high tolerance and allows for smooth rotating while mounted on a tripod. Matches the barrel perfectly, too.
Hugh
beachbum2277
May 01, 2008 15:37 |  #4
Yeah, you're gonna need the the tripod collar with the 70-200. I also bought one off of ebay for $15 and the construction of it is nice. Nice fit, heavy metal construction... Go with that one and you'll be set.
Bryan Docter Fine Art Photography - www.bd-photos.com (external link)
RPCrowe
Joined Nov 2005
May 01, 2008 15:50 as a reply to  @ hughps's post |  #5
Not necessary but, really nice to have...
The 70-200mm f/4 (series) lenses are light enough to use without a tripod ring/collar. However, I far prefer using a ring when shooting with the lens.
The tripod collar will allow you to rotate your lens from horizontal to vertical or to tweak the horizon level. Believe me, it is a lot easier to shoot a vertical when your lens is centered over the tripod head, rather than hanging off to the side.
It is also, IMO, easier to follow moving subjects when using a tripod ring because the camera/lens is balanced better on the tripod head.
Finally - although it may be safe to use this lens with the camera mounted on the tripod head; I would be hesitant to carry the tripod over my shoulder with the camera/lens mounted in this fashion. This would be especially true when using a Rebel (series) camera which uses a plastic tripod socket!
I bought a used Canon tripod ring years ago and an very happy that I did. However, I would now buy one of the Chinese Rip-offs advertised on eBay at one heck of a savings over the OEM ring. China is producing some quality replacement parts these days and I would have no problem trying the ring.
Chinese products aren't all that bad...
I use a Chinese Rip-off lens hood for my 17-55mm f/2.8 IS lens and it does everything as well as the OEM model at a fraction of the price. I also use Chinese Rip-off lens caps for some of my lenses. I don't use these because of the cheaper price; since Canon was generous enough to provide lens caps with my lenses. I use the Chinese Rip-off hoods because IMO, they are superior because they are center pinch caps while the Canon caps are side pinch. It is easier for me to remove and replace a center-pinch cap when I have a sun shade mounted.
beachbum2277
May 01, 2008 15:50 |  #6
Here you go, this is the one I got. CLICK HERE (external link)
snatiep
May 02, 2008 14:07 |  #7
Thanks everyone! I went ahead and ordered the one beachbum2277 recommended. Hopefully it wont take six months to get!
Nate
Tsmith
Formerly known as Bluedog_XT
May 02, 2008 14:10 |  #8
Smart move as you'll quickly see that the setup will feel better balanced using the collar.
beachbum2277
May 02, 2008 14:14 |  #9
snatiep wrote in post #5448271 (external link)
Mine actually didn't take that long to get, maybe a week or so.
Mr. ­ Bill
May 02, 2008 14:16 as a reply to  @ Tsmith's post |  #10
Just bought one of those collars too. Thanks for the link beachbum2277!!
btw, does anyone recommend using the collar on a monopod as well as a tripod??
Link to my Pictures (external link)
beachbum2277
May 02, 2008 14:25 |  #11
newbietoslr wrote in post #5448316 (external link)
I believe if you're going to use the monopod you should use the collar too. My understanding is that the collar's purpose is to evenly distribute the weight of the camera with the weight of the lens so that one, it's balanced and two, you take the pressure off of the lens mount. So, after that long explanation, yeah, anytime I use that lens on a tripod or monopod, I use the collar.
eeeksNYC
May 02, 2008 22:53 |  #12
I bought one similar to the one suggested. It does balance quite nicely on a tripod with the collar.
In fact, I may be in the minority that found the f4L a bit too light. So, I find myself keeping the collar on even when I'm handholding.
I'm weird that way.
eeeksNYC (my blog (external link), my flickr (external link))
zeiss ikon icarex 35s,5D MK1/ EF 28-70 f2.8L / Sigma 50mm f1.4 / Sunpak 383s / Cybersyncs / and a couple bags of other stuff....http://www.flickr.com/​photos/29075737@N02/ (external link)
Tsmith
May 02, 2008 22:55 |  #13
eeeksNYC wrote in post #5450971 (external link)
I'm weird that way.
Mine never comes off either - ;)
skylife
May 03, 2008 02:47 |  #14
i also found this lens a bit too light and i also leave the collar on when handholding. doesn't get in the way of the zoom ring.
Stormin_24
May 03, 2008 02:49 |  #15
Definitely get the collar... Peace of mind is alot better than lens on ground...
New Hampshire State Bird: Purple Finch
http://www.netstate.co​m …birds/nh_purple​_finch.htm (external link)
Gear
Norman
Did they get you to trade, your hero's for ghosts?
8,034 views & 0 likes for this thread, 14 members have posted to it.
2762 guests, 163 members online
