Thread started 30 Nov 2004 (Tuesday) 21:44
Airshow Photography
crazyfoo88
Joined Sep 2004
Nov 30, 2004 21:44 |  #1
For next year, I will be doing some of the airshow photography around ontario/southern states. I am wondering what is the best lens for the money, as it will be on my digital rebel.
Also, please realize that I am 16, and I can not remortgage my house to get some really big lens :lol: I just want to know what setup is best for the DRebel for aviaton photography!
Donations would be greatly accepted if you are in the festive spirit ;)
Thanks!
Andrew C :)
My Flickr (external link)
BoySpot
Joined Feb 2004
Nov 30, 2004 21:56 |  #2
While the 100-400 would probably be the one to have, I guess from your message that it is going to be a bit over the top. One of the zooms to 300mm will be a good compromise. Recent reviews in a UK magazine (I can't remember which one) were harsh about the 75-300mm Canon lenses but quite favorable about the 100-300 Canon zoom. I have a far older version of this lens but it still seems to do the trick for me until I can summon the funds for the 100-400.
Hope this is of help. Enjoy the shows when the weather gets nice again.
nosquare2003
Joined Dec 2003
Nov 30, 2004 21:59 |  #3
What lenses do you have now?
Anyway, I don't know the best lens for you. I hope others can help.
(Urr...IMHO, 2 bodies are useful for airshow...)
crazyfoo88
Joined Sep 2004
Nov 30, 2004 22:01 |  #4
Are you talking about this lens? 75-300 4-5.6 III USM?
If so, I already have it. I notice it isnt too sharp however.
Id love the 100-400L IS, but its too expensive brand new for me. I could probably get the money for a used one, so if anyone has one laying around, I would be really interested in it :D
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Nov 30, 2004 22:11 |  #5
There is not much between the 70ish-300mm lenses and the 100-400mm unfortunatelyu...
About the only thin thats in between would be the Sigma 100-300mm f/4 with a 1.4X T-con. (140-420mm f/5.6)
Otherwise I'd say your stuck with the 75-300mm.
CDS' HOT LINKS
mjordan
Joined Apr 2002
Nov 30, 2004 23:00 |  #6
The first airshow I did with my D30 I had the 70-200 4.0L lens. It did a great job for most of the passes and stunts. I also made sure I got there earily so I could find a spot in the middle of the viewing area so I was right where most fly bys were centered on. And I had the sun behind me as much as possible.
But I got some excellent shots with the 70-200 4.0L. The next airshow I had both the 70-200 2.8L IS and the 100-400 4.5/5.6L lenses and I left the 100-400 on all the time, even though there were times when the 70-200 would have been a better lens for the distance I was shooting.
Mike
Hillsboro, OR
Canon 1DMKII and lots of "L"
http://www.sitnprettyp​hoto.com (external link)
Xtreme02
Joined Mar 2004
Dec 01, 2004 00:52 |  #7
I just shot an air show recently with my Drebel and 100-400mm lens and it work out well. I seen a few people with the 70-200mm lens. for the most part i was shooting at the 400mm range. I also seen a few people with the 300mm F4 and that would also be good. I also was switching between my 17-40mm lens when the jets flew right over head. Like sated in previous post. get there early to get a good seat as i'm sure more people will start to crowd and its hard to pan with out hitting other peoples heads. Good luck with the lens choice.
johneo
Joined Aug 2003
Dec 01, 2004 09:59 |  #8
I bought my 100-400 specifically for the RI Airshow this past June. Expensive and may be hard to do at 16 but worth the effort to work and save if you are serious about your photography.
I'm sure there are other good lenses out there (as others have mentioned) and they may save you some money but not using those, I couldn't tell you anything about them.
Most of the photos, in the link (all sky shots, I think??) are with the 100-400 L
My Airshow Pics (external link)
2 - 5DMKII's, Powershot SX 150 IS
7D, 5D, IR/5D, 10D, IR/10D, Elan 7NE
17-40 L, 24-70 L, 70-200 f/2.8 L IS, 100-400 L IS,
TS-E 24 f/3.5 L, 28-135 IS (x2), 50 f/1.8, 85 f/1.8 550EX, 430EX
40mm pancake
Jon
Joined Jun 2004
Dec 01, 2004 10:09 |  #9
Generally if you're trying to zero in on an individual aircraft you're going to need 300+mm, even with the cra^hop factor. For formations, and sky patterns (smoke trails, etc.) it can go as wide as 35-50 mm.If you're willing to give up on tight shots on the aircraft, a 75-300 will be adequate, but you'll be limited in how far you can enlarge it. I'd say that IS is really useful here, too.
Jon
Cocker Spaniels
mjordan
Joined Apr 2002
Dec 01, 2004 10:19 |  #10
Jon, actually, the IS doesn't work very well for airshows. I thought the same thing you did until I read the advice of another photographer that shoots a lot of airshows that said to turn IS off. I tried this with my last airshow this summer and he was right. With all the twisting and turning you do as you follow the planes and jets, it can confuse the IS and cause blur. For the more static displays and slow aircraft, gliders and parachutests it's probably ok. But I just left mine off the whole show.
Mike
Hillsboro, OR
Jon
Joined Jun 2004
Dec 01, 2004 10:24 |  #11
Depends on who and where you're shooting. Crossovers, vertical climbs, or the like, low-speed fly-bys, quite a number of maneuvers are linear and can be anticipated, so IS in panning mode will help. It doesn't help for everything (does anything?), but it's certainly not something to shun.
Jon
Cocker Spaniels
gramps
Joined Oct 2004
Dec 01, 2004 12:24 |  #12
those are some GREAT shots...........would you mind sharing what your settings were (shutter etc.)?
THANKS
Some pics here - http://pbase.com/sjh (external link)
20 D; 85 1.8; 24-70 L; 70-200 f4L (sold); 100-400 L; 420 Light bulb
1550 Pelican "soft case" & too much junk!!!
johneo
Joined Aug 2003
Dec 01, 2004 16:15 |  #13
THANKS
Hi Gramps!
Not sure but I know I was shooting in shutter priority and probably 1/180th - 1/250th. I also had IS mode 2 on the entire day, figuring I'd be spending the day panning back and forth. It was the 1st real test for the lens and it made me one happy Canon camper! :D
40mm pancake
phili1
Joined Oct 2003
Dec 01, 2004 19:11 |  #14
I own the Cano 70 to 200 F4 L and it is a great lens. I also own the 100-400 L and like wise is a great lens but twice the price.
So thses are your alternatives.
Canon 70-200F4 L $600+
Sigma 80-400 OS ( new Image stablized) $890.00
Sigma 50 to 500 lens ( One of the sharpest on the market. $800+
Sigma 135-400 around $500+ but has great reviews
Tamron 200-500 around $800+
I tried the Tamron and was not happy with it but you may be.
I own the Canon and my friend owns the Ssigma 80-400 and both are good.
Another friend has the Sigma 50 to 500 and the pictures are awsome but it is heavy.
For air photos I think the Canon 70-200 and Sigma 135-400 are the lightest.
You can go to Fred Miranda and read reviews
http://www.fredmiranda​.com …duct=181&sort=7​&thecat=29 (external link)
MKII N-Canon 20D - Tamron 90MM F2.8 Macro -
Tamron 17-35 F 2.8-4 - Canon 70-200 F4 L
Canon 100-400 F4.5-5.6 IS L - Kenko Pro 300 Ext 2 X - 420 EX
crazyfoo88
Joined Sep 2004
Dec 01, 2004 20:28 |  #15
http://cgi.ebay.com …4687&item=38564​30941&rd=1 (external link)
So if I can get the 70-200L for say, 600 CAD (about 450 USD) it would be definately worth it? I already have the 75-300, but I want better quality glass.
6,476 views & 0 likes for this thread, 20 members have posted to it.
Airshow Photography
2247 guests, 126 members online
