Looking to get into macro, and want to start with some tubes.
Please post some shots with tubes, and which kind.
AngryDad Senior Member 783 posts Joined Apr 2007 Location: Split time, Illinois/Tanzania More info | May 02, 2008 03:00 | #1 Looking to get into macro, and want to start with some tubes.
Samdiver74 Goldmember More info | May 02, 2008 06:52 | #2 Here is a quick shot I took a couple of weeks ago with the Kenko Extension tubes 36mm and 20mm on my Canon 100-400 set at 130mm.
Here is a 100% crop of the neck scales.
Allan
okiediver Member 93 posts Joined Dec 2006 Location: Claremore, OK More info | I bought a set of Kenko tubes and am using my nifty 50. Can someone tell me what the ideal settings would be using this setup? I look thru the viewfinder and the DOF is so narrow it is unreal. Is this normal? Should I be manually focusing? I think so, but I believe the tubes are for either one--they are new for eos systems apparently. Canon Rebel 400D, 85mm F1.8, Sigma 17-70, borrowed 50mm. Canon G9, IKE housing.
macrojunkie Cream of the Crop 6,709 posts Likes: 2 Joined Jul 2007 Location: Somerset - UK More info | full set of kenko tubes will give u 2:1 life size. Uk prayingmantis forum - http://www.dragonscrest.co.uk/forums/index.php
Ook Senior Member 648 posts Joined Mar 2008 Location: Toronto, Canada More info | May 02, 2008 13:55 | #5 macro junkie wrote in post #5447875 full set of kenko tubes will give u 2:1 life size. That's for a 100mm (or other, I reckon) macro lens though. I am fairly certain that 68mm of tubes on a nifty will give you 1.47x. John-Allan
Ook Senior Member 648 posts Joined Mar 2008 Location: Toronto, Canada More info | May 02, 2008 13:59 | #6 okiediver wrote in post #5447851 I look thru the viewfinder and the DOF is so narrow it is unreal. Is this normal? Should I be manually focusing? I think so, but I believe the tubes are for either one--they are new for eos systems apparently. If I'm wrong on this, someone please correct men, but through the viewfinder with that setup your aperture will be as wide open as possible to facilitate focusing, so on the 1.8 at macro magnifications that's *razor* thin. Set your aperture lower - 8 to 11, for example, and use of that DOF preview button! See if that helps. John-Allan
okiediver Member 93 posts Joined Dec 2006 Location: Claremore, OK More info | I think I was using an F4 or so, I will try that. How do I mount the 50 in reverse? Is there a adapter ring or something--can someone provide a link? Canon Rebel 400D, 85mm F1.8, Sigma 17-70, borrowed 50mm. Canon G9, IKE housing.
Ook Senior Member 648 posts Joined Mar 2008 Location: Toronto, Canada More info | May 02, 2008 23:05 | #8 Hi okiediver, the reverse-mount comment was directed at "angry dad". Since you already have tubes, I don't think you'll need to bother with reverse-mounting. (up to) 1.5x with your nifty+tubes is *plenty* of magnification to work with for the time being. Reverse-mounting means you lose autofocus and aperture control (on newer lenses you have to set aperture and remove the lens while holding the DOF preview button before reverse-mounting). Stick with the tubes you've already got John-Allan
okiediver Member 93 posts Joined Dec 2006 Location: Claremore, OK More info | That does help, I am going to do more experimenting today. Canon Rebel 400D, 85mm F1.8, Sigma 17-70, borrowed 50mm. Canon G9, IKE housing.
Rutha73 Senior Member 571 posts Joined Apr 2007 Location: Mesa, AZ More info | Wow Ook, that is an expensive rig! I am going to order the ring that lets you mount one lens face to face with another today, I have tried reversing the kit lens and holding it up to my camera, you get good magnification but its a pain! http://www.bhphotovideo.com …ge.jsp&A=search&Q=*&bhs=t ~Jake AZPOTN
| Latest registered member is Marcsaa 494 guests, 158 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
