siejones wrote in post #5456734
Thanks I will start work on it when I can. Although I won't be covering the basic's such as Aperture/Shutter speed/ISO and the reader will need a good understanding of these and what dynamic range means (all of which have already been perfectly explained on here already) before hand. In other words this will be an advanced users guide and won't fit under the catagory of "beginners".
Of all the books and articles I have read I have never really seen any of them attempt to properly explain how metering works (apart from one ansel adam's book) probably because it's a real toughy to explain. I will really have to think about how to explain it myself. I will probably try to use the basic's of the zone system modified for media with much less dynaimc range. Most people are on the edge of understanding it but not quite there and hopefully I would be able to push them that last final step and make it all click into place.
Let's put it this way. No matter which metering mode I choose I can now truly say the camera will hold no suprises for me. I can now control the camera exactly how I choose and not vice versa
Now it's just finding the time
siejones,,,camera exposure meters measure what is called 18% Reflectance Grey..18% Reflectance Grey is a tone of grey that is reflected off the subject while 82% is absorbed..
Exposure is a reciprocal E = intensity X time where intensity is the aperture and time is the shutterspeed..If you change one value you must change the other to get the same value for E (exposure)
For example - 1/125th @ F/8 is the same as 1/250th @ F/5.6 or 1/60th @ F/11
A camera's TTL meter is a reflectance meter meaning it measures the light reflecting off the subject..Reflective meters can easily be fooled by backlighting, white or dark backgrounds and even strong coloured light sources ( a red spotlight for example )..For the most accurate metering meter with what is called an incident meter which measures the light falling on the subject..Most flash meters are incident meters..You have probably seen the photographer or assistant hold a handheld meter very near the subject,,this will most probably be an incident meter..
It all comes to experience when metering and I stress when you are metering a subject in difficult circumstances like backlighting use your camera on Manual..Fill the frame with the subject, meter the subject and take an exposure reading..Skin tones are pretty much in the ball park but naturally will vary, grass is also good.. Bracket your exposure either side is a good idea if you want that "perfect" exposure..
