DANATTHEROCK wrote in post #5477805
I still am unsure of how to properly meter the foreground.
I shoot in Av mode.
First of all metering, use spot metering if you want, I do. If your camera does not have that then try partial. Aim down and point the centre of the viewer at the most "average area" of the scene. If there is no average area then meter the brightest and darkest part, see how much the shutter speed changes and then average it yourself. You can average the shutter speed or the number of stops if you know how. Then use the dial near the shutter button to apply Exposure Compensation, if you need to.
Alternatively, and probably easier try M (manual) mode: What is the aperture you are setting it to and what is the shutter speed the camera is picking? Lets say the aperture you choose is F/8 and the shutter speed settles at 1/125. Well, now move the command dial to M for manual and preset the aperture to F/8 and the shutter speed to 1/125. Then, when you move, the settings remain as they are.
It is quite a simple step from AV to manual. For Depth Of Field on landscapes (front to back sharpness) you want F/8 or F/11, then you just need to change the shutter speed until the meter in the viewfinder places the mark in the middle of the grid:
Sometimes you will need to over or under expose slightly depending on the scene you are metering, but this takes a little more typing to explain. Basically the camera's metering system is metering the scene to 18% gray and for some scenes you need to compensate for its best guess. White will underexpose, black will overexpose and any graduation between will under or over expose. Just remember that the camera is always "best guessing" because it doesn't have eyes that can read and react to light like we do.
DANATTHEROCK wrote in post #5477874
Do I use "Exposure lock". Just read about it in a tutorial here. Not sure how to use it, but is this how I meter the foreground, then recompose and keep those readings? I am sure that I am making this more complicated than it should be. But I am going to Alaska (Kenai Peninsula) in less than two weeks. Help!
Yes, you can use this too. Point the camera down to get it to meter then press the exposure lock button, recompose and you can then place the filter and shoot. The exposure resets when you trip the shutter so you have to lock it each time. Manual is easier
Trying using Manual for your landscape shots and AV for all your other shots, You'll soon learn and get comfortable with M mode.
