Thread started 04 May 2008 (Sunday) 08:48
Honest feetback reguired
Northern ­ Tony
May 04, 2008 08:48 |  #1
Hi,
This is an early morning shot taken of Lake Windermere in the Lake District, UK.
Looking for honest feedback for this shot. Been working on my composition lately and wanted to know if I was going in the right direction.
Please be honest, if you don't like say but explain why so I can learn.
Northern Tony
Canon EOS 40D, EOS 350D & more gear than I started with and know how to use properly!
http://www.tonybaileyp​hotography.com/ (external link)
Gary ­ Lindquist
May 04, 2008 09:02 |  #2
Tony, composition is fine, but post processing needs work.
As far as composition, the hill along the left edge should be cropped off as there is not enough of it. Along the right edge you have a boat chopped in half and it should be cropped off as well. The bottom edge, you have a rock the is chopped off at its bottom edge and it should be cropped as well.
One thing you can't fix is the sail reflection falls onto the large foreground rock. Would have been better if it was fully reflected.
Post processing: The sky is not very lively. It looks as if you tried to bring it around but it is still not very interesting. You might try carefully post processing in a new sky. The rest of the image needs contrast and saturation bumped up. The white thing in the water should be removed and the stick in the upper, left quadrant.
Gary
Gear: Canon 5D, Canon EF 17-40mm f/4 L USM, Canon EF 70-200mm f/4 L USM
Northern ­ Tony
May 04, 2008 09:11 |  #3
Gary Lindquist wrote in post #5457748 (external link)
Hi Gary,
Thanks for the feedback, I really appreciate it. It always helps to have another pair of eyes!
Never noticed the boat chopped in half, so yeah needs to go! Again, agree about the rock and the white thing floating in the water ( I think that this is buoy but not sure).
Currently, I am working on my pp and will continue to post on here for feedback.
Thanks again.
Northern Tony
Gary ­ Lindquist
May 04, 2008 09:18 |  #4
You're welcome, Tony.
Gary
chauncey
May 04, 2008 10:08 as a reply to  @ Gary Lindquist's post |  #5
http://www.amazon.com …oks&qid=1209913​187&sr=1-2 (external link) is the first suggestion that I would make.
The things that Gary suggested are spot on.
Learn how the eye travels across the image (upper left to lower right, like we read), try rotating the image to see if the eye is drawn to the same place
and is that the focus point that you had in mind when you composed the picture.
midnitejam
May 04, 2008 21:14 as a reply to  @ chauncey's post |  #6
In regards to composition, the current comp is just ok, But I think this image has possibilities of two separate outcroppings.
In regards to saturation, sharpnes and focus it is pretty much common for a digital camera. A little photoshop and you could possibly have something really terrific.
Midnitejam--The happiness in your life depends on the quality of your thoughts.
Anke
May 04, 2008 21:26 |  #7
Compositions not bad, but I reckon the use of a polariser to get to see underneath the water slightly in the foreground would've been fantastic.
Anke
Northern ­ Tony
May 05, 2008 05:54 as a reply to  @ Anke's post |  #8
Thank you to Chauncey, MidniteJam and Anke for your valuable comments.
Hopefully, I will be able to think a little more about the shot before i click!
Northern Tony
720 views & 0 likes for this thread, 5 members have posted to it.
2602 guests, 167 members online
