Thread started 04 May 2008 (Sunday) 17:01
Can I somehow put a UV filer on my A570 IS?
mamadu.bwana
May 04, 2008 17:01 |  #1
Hi everybody,
I have recently bought a A570 IS PowerShot and I *love* it. The one thing which I wish I could do with it (besides having an external flash) would be to somehow mount a UV filter on it.
Is there any way to do this with my camera?
Thanks,
Mamadu
Jon
Joined Jun 2004
May 04, 2008 19:28 |  #2
Well, a UV filter really only helps protect the lens. When the camera's turned off, the lens is covered anyhow. You can get a lens adapter, either from Canon (LA-DC52G; which also fits the A590) or from a third party such as Lensmate Online. They are threaded for standard filters and you can mount a UV (or polarizer) to them.
Jon
Cocker Spaniels
mamadu.bwana
May 04, 2008 19:38 |  #3
what kind of lenses, besides a UV filter, can I put on my A570IS if I get this adapter?
and how is such an adapter different from this (external link)? What does this 'adapter tube' do?
Jon
Joined Jun 2004
May 04, 2008 19:54 |  #4
That's pretty much what it is. The bezel around the 570's lens can be removed and the adapter mount put in its place. You can then add filters or auxiliary close-up, telephoto adapter or wide angle adapter lenses to it. I know nothing about Bower's products. Lensmate is well spoken of.
Jon
Cocker Spaniels
mamadu.bwana
May 04, 2008 19:58 |  #5
thanks for the reply.
I am still confused about one thing though: just adding an adapter does nothing in itself, right? I need to purchase an adapter AND then a telephoto, or macro, of filter, etc. Correct?
Jon
Joined Jun 2004
May 04, 2008 20:08 |  #6
Right - the adapter just gives you an attachment point. Without it, you can't use any other things, but without them all it does is stick out around your lens.
Jon
Cocker Spaniels
abuseddog
May 04, 2008 20:27 as a reply to  @ Jon's post |  #7
Pretty sure this is the same one that I bought.
Took awhile to get here....about 41\2 weeks, but it works pretty well.
http://cgi.ebay.ca …ZWDVWQQrdZ1QQcm​dZViewItem (external link)
audiobomber
May 05, 2008 12:39 |  #8
abuseddog wrote in post #5460894 (external link)
But doesn't it partially block the optical viewfinder and the flash?
abuseddog
May 05, 2008 14:52 |  #9
audiobomber wrote in post #5464743 (external link)
Quite right, it does block the optical viewfinder. esp. with the rubber lens hood attached. The flash is blocked about 30%, I have no experience with it though, as I don't normally take flash pics.
One thing I did notice, was the extra size makes it harder to carry conveniently.
jscotti
May 05, 2008 17:49 |  #10
The LA-DC52G allows you to mount both 52mm filters as well as the adapter lenses. I have the Canon WC-DC52 wide angle converter that gives a 0.7 magnification - nice to have that extra field of view sometimes. I had bought that adapter lens for my old A75 which used a different lens adapter than the A570, but the adapter is only about $19.95 (at Adorama).
While Jon seems to poo-poo the poor old UV filters, they really do help reduce haze in images, not just acting as a lens protector (though I'm sure many UV filters have given their lives in that service....). I also have a 52-58mm up-converter that allows me to use all those 58mm filters that I have for my 20D's lenses.
Jim.
Canon 20D; Pair of Canon A570is in stereo rig; Olympus OM-2.
Photoblog: http://pixofmyuniverse​.blogspot.com (external link)
2,049 views & 0 likes for this thread, 5 members have posted to it.
1064 guests, 147 members online
