Thread started 06 May 2008 (Tuesday) 06:13
How to use eight flash units at once
Curtis ­ N
Master Flasher
May 06, 2008 06:13 |  #1
I feel so unworthy of my title now, since I only carry three flash units in my bag.
Check out today's Strobist post (external link), and be sure to look at the original size image (external link) and zoom in on their lighting rig. This is what happens when David Hobby and Joe McNally get together in the presence of a beautiful blonde Czech model (too much testosterone).
I can't wait to read the rest of this story!
ANGUS
May 06, 2008 06:17 |  #2
Look forward to his video of it!
EDIT: Wonder if it was simply to achieve a larger light source?
Angus
| 1D MkIV | 1D MkIII | 5D MkII | 15FE | 16-35 f2.8 L | 24-70 f2.8 L | 70-200 f2.8 IS L II | 35 f1.4 L | 135 f2 L | 300 f2.8 IS L | 580 EX II | 580 EX II |
Michael
May 06, 2008 06:19 |  #3
I saw that. I also look forward to the video.
Michael
martinsmith
May 06, 2008 06:46 |  #4
I did a shoot at the weekend and used my 3 flashes initially then borrowed a couple and went to 5 with 4 having gels on. May have to trawl ebay for some more.
David Hobby must realise how responsible he is for the huge price hike in the 2nd hand market!
[SIZE=1]ms-imaging (external link)
sfaust
May 11, 2008 01:55 |  #5
NSWESP wrote in post #5469668 (external link)
My guess is that they were trying to increase the power output. You can get a large light source with one strobe if you position it front of the reflector, so there isn't any need to add more. If they were using them direct, there would be multiple shadows from each light. So I'm guessing they had the diffuser between the model and the strobes, and where adding power with multiple 800's.
For power to get 1 extra stop of light, you need two flashes. To get the next 1 stop increase, you need to add 4 more. And for the next increase, 8 flashes. If you were insane enough to want a 4 stop increase, better whip out 16 strobes! So they can add up quickly if you need 2 stops or more.
Based on the distance from the strobes to the model, bright sunlight, and with a diffuser in-between (if they didn't use it overhead), I bet they were on the low end of the power scale with a single strobe.
Stephen
Mix of digital still gear, Medium format to M4/3.
Canon EOS Cinema for video.
Commercial Photography (external link)
bieber
May 11, 2008 08:59 |  #6
Screw the video, I just want to see the photos they made with that rig...
EOS 20D w/ BG-E2 grip
Nifty fifty, EF 28mm f/2.8, EF 70-200mm f/4L USM
Speedlights SB-25/SB-26/580EX, Pocket Wizards and such
My Gallery (external link)
Curtis ­ N
Master Flasher
May 20, 2008 22:55 |  #7
Update: Strobist tells the story, in words, pictures and video, on his blog:
http://strobist.blogsp​ot.com …mcnally-desert-shoot.html (external link)
Joe McNally also blogged his version:
http://www.joemcnally.​com …5/19/david-of-the-desert/ (external link)
My favorite line from McNally:
We picked a charming spot right by some petrified camel sh!t and went to work.
2,170 views & 0 likes for this thread, 6 members have posted to it.
1545 guests, 135 members online
