Anyone having this problem with lightroom: I'm getting an error when importing to Lightroom from DVD and CD disks burned today (worked fine 2 days ago and I have not been near either computer till today). One or two photos import (out of a large amount - images are RAW) and then it quits with a pop-up, which at the very top says "Import Results", and under there it says, "Some import operations were not performed." In the space below there's a header that says, "Could not copy a file to the requested location. (92)" (Not always 92, sometimes 200 or something else), and there is a triangle to expand and all the photo file names are listed below.
Lightroom is fine with images burned to disks 3 days ago (the last time I used either computer) but nothing burned today will import. This is happening on two computers one is running XP with Lightroom 1.4 the other is running Vista with Lightroom 1.3. I can import one image at a time but no batches off DVD or CD burned today, I have not tried directly from my CF cards (but have heard on another board that someone was having problems with them as well). We have found a work around; download all images to temp folder on desktop then import into Lightroom after imported delete files in temp folder it works but takes a lot more time and space on hard drive.
By the way we have also used two different DVD burners and softwares to create the DVDs and CDs. We are leaning strongly to Lightroom at this time any help greatly appreciated as I have a lot of images to import and process.
