Thread started 07 May 2008 (Wednesday) 01:28
New to Aperture - quick questions
Damo77
May 07, 2008 01:28 |  #1
Hi everyone, I've just been given Aperture 2.0 to play with, and I'm dabbling with a folder of Raw files. Until now I've only used ACR (a lot) and DPP (a little).
Q1: If I've made an adjustment to the White balance, for example, I can turn the WB tick box on and off to see the effect of my WB adjustments. But if I've made several adjustments (eg WB + Exposure + Levels) how can I view before & after? I can turn off the tick boxes one by one, but that's not satisfactory. ACR has a "Preview" tick box which I usually use.
Q2: Once I've made adjustments to one image, how do I apply those adjustments to other images in the library?
Thanks for your help.
Damien
Website (external link) | Facebook (external link)
Damo77
May 07, 2008 01:36 |  #2
I figured out Q2 - still stumped on Q1.
Damien
sf1
May 07, 2008 07:19 |  #3
Damo77 wrote in post #5476078 (external link)
Hi Damo77.
A1: You could un-check each box, but that is time consuming. Why not simply click between the master and your newly revised version? You usually can do this by simply clicking the arrow buttons. Or you could put both of them up on screen at the same time using the compare mode.
A2. Use the lift and stamp tools. Lift will copy all your adjustments - you can pick whichever adjustments you want to copy, and the stamp tool creates a new version when applied to a new pic.
You can get lots of really good info by watching these movies:
http://www.apple.com/a​perture/tutorials/ (external link)
Canon 5DII, Canon 1D Mark II N
Canon 24-70 mm f/2.8 L, Canon 85 mm f/1.8, Canon 70 -200 mm f/2.8 IS L, Canon 400 mm f/5.6 L, Canon 50 mm f/1.4, Manfrotto 055XPROB & 488 RC2
Canon Speedlites 580 EX, 430 EX II & 3 PW II, iMac I7, MacBook Pro, Aperture 3, CS5
Damo77
May 07, 2008 07:20 |  #4
Thanks heaps, sf1. I'll try that when I get to work tomorrow.
Damien
randomlinh
May 07, 2008 12:43 |  #5
yeah, if there's a quick key to do this, other than navigation (because sometimes the original is not next to the current edit I'm doing), I'd like to know. I found in Lightroom it was really nice to have that history list, and sort of miss that.
sf1
May 07, 2008 17:26 |  #6
randomlinh wrote in post #5478809 (external link)
Well I had to get out the quick guide to figure this one out.
If you edit any master, it creates a version. You can scroll between the master and version to see what you have done by simply clicking the "M" key. This allows you to go from version to master and back to version --> very quick and easy, easier then using histories.
Right ­ Cranium ­ Imaging
May 07, 2008 17:26 |  #7
Press M for the Master Image
(Insert Over Used Photography Quote Here)
Canon Equipment - Mac Computers
Damo77
May 08, 2008 05:05 |  #8
Yep, M is the answer. Thanks everyone!
Damien
1,757 views & 0 likes for this thread, 4 members have posted to it.
1063 guests, 104 members online
