Thread started 03 Dec 2004 (Friday) 22:36
How would you set your camera in this situation? Help!
Kim22
Joined Sep 2003
Dec 03, 2004 22:36 |  #1
I'm going to take a family portrait tomorrow, using my G3. We'll be outside (supposed to be partly cloudy) at a park. There's just two parents and two sons. We're doing this in the late afternoon, so not too bright of sun. I have a 420EX.
Normally I just use Auto, ( :oops: ) but I want to learn how to use the other settings. In the situation above, what would you set your camera at? (I know what aperture and shutter speed are, but I don't know how to use them correctly.) Would you use the 420, or just sunlight?
Please tell me exactly how you'd set your camera/flash and explain why you chose what you did. Thanks so much! I'm determined to figure this out! LOL
Kim Youra Photography (external link)
Baby and Children's Portraiture
40D and Tamron 17-50 2.8 (and occasionally 28-75 2.8 )
Alien Bees studio setup
cmar
Dec 03, 2004 22:59 |  #2
If you can have the sun to your back, no flash needed.
If you want more options, then use the flash for fill if needed, like if the faces are shadowed, or if it is sunny out and the subject is in the shade.
I often use P mode, as it lets you control things a little more if needed.
You can try and de-emphasize the background a little by shooting in Av, and using f2.0, then zooming out and getting as close to the subject as possible.
If the background is interesting, use a larger aperture so everything is in focus.
Try for a background that is appealing, but not distracting to the main subject.
twl845
Joined Nov 2003
Dec 16, 2004 16:14 as a reply to  @ cmar's post |  #3
My only addition to the reply above, is to make sur ethe shutter speed is at least 1/90 to ensure there's no movement.
Canon G3, Kodak DC4800, Elements3
bauerman
discount on value meals
Joined Apr 2003
Dec 17, 2004 12:00 as a reply to  @ twl845's post |  #4
I find that the G3's internal flash unit works quite well for outdoor fill flash every now and then. You may want to give that a shot - you may need to dial it down a few notches using the FEC setting under the "FUNC" button of the camera.
Biko
Joined May 2003
Dec 17, 2004 14:16 as a reply to  @ bauerman's post |  #5
If not very cloudy I would have them about 90degree to the sun as shooting with your back to the sun means they will be looking into it and squinting.
Use your 420EX as fill in flash and use some sort of bounce that is suggested in other thread (stofen one has some advice). Take a number of shots ideally AV so you can control DOF, I would check images before they move off to make sure that no one has blinked.
DocFrankenstein
Joined Apr 2004
Dec 18, 2004 17:43 as a reply to  @ Biko's post |  #6
Biggest focal length
Smallest aperture
I'd place them so that the sun is to their side. They wouldn't squirt.
Lowest ISO
The background is as far away as possible...
What's the sync speed of that cam?
National Sarcasm Society. Like we need your support.
1,977 views & 0 likes for this thread, 6 members have posted to it.
2187 guests, 129 members online
