DocFrankenstein wrote:
It's just that potentially, the quality of with the filter can be higher.
Well, theoretically, having a filer between the subject and the camera would make for a lesser quality image than without one, wouldn't it? Although, in all practicality, the filter shouldn't make a difference in image quality.
However, if you do shoot in color without the colored filters, you can always simulate those colored filters in PS. For example, using a red filter would be the same as using the red channel of the image in PS. If you want to control the density of the red filter effect, then you can overlay the red channel image over the luminosity channel image and vary the opacity of the red channel image.
By the same token, you can simulate a yellow filter by using the red and the green channels, and likewise, vary the density the same way as described above.
I think shooting color and converting to BW gives you more processing options than just shooting in BW and using colored filters which really can't be undone if you decide that that's not the effect your really wanted.
