Thread started 09 May 2008 (Friday) 07:42
Change picture orientation
40piggies
May 09, 2008 07:42 |  #1
Anke
May 09, 2008 07:48 |  #2
You mean rotate the image or crop out a portrait shot from an existing landscape shot?
Anke
40piggies
May 09, 2008 07:53 |  #3
Anke
May 09, 2008 09:03 |  #4
Therefore you need the crop tool. You can set the crop, i.e. 4x6 in the options.
Anke
dcsmith40D
May 10, 2008 06:57 |  #5
I don't have elements. You need to crop the picture in 3 x 2 ratio. You took the picture in 2 x 3 ratio.
Canon 40D; 50 f1.8, 70-200 f2.8 IS L, 580 EX II, 1.4 TC, 24-70 f2.8 L, (2) 430 EX II
David
CanadianKitKat
May 10, 2008 09:07 as a reply to  @ dcsmith40D's post |  #6
Raw won't make any difference at all when you are changing the orientation. Raw's capabilities come into play with things like exposure, colour and white balance, not composition. Also I use CS3, but I'm thinking elements must have these basic features as well.
If you want the entire thing rotated, rotate the canvas 90 degrees. If you want to crop it out, click on your crop tool, set the size in the tool bar to 4 in x 6 in drag your mouse over it and then position the crop where you want it. If you specify the size then it will limit you to that size of crop. Hit enter when you're ready and there you go.
www.ktklassen.com (external link)
1,516 views & 0 likes for this thread, 4 members have posted to it.
2844 guests, 154 members online
