Thread started 10 May 2008 (Saturday) 11:26
Canon 5D cable release problem
glennolsen
1 post
May 10, 2008 11:26 |  #1
I am having an issue with my 5D that I have not had in the past. When using a cable release, either the Canon model or using a Pcket Wizard II with the correct cable, I can shoot successfully for a period of time and then the camera seems to go into a shutter release pressed mode and will not go out until I unplug the cable. Sometimes unplugging the cable will not work and when reinserting it, the shutter fires without the button pressed. Has anyone experienced this and can point me in the right direction? Thanks...
Glenn
offtheroad
Aug 29, 2008 14:31 |  #2
What model of cabel relaease do you have. I haven't purchased one yet for my 5D. Which one would you rcommend?
jbechdel@comcast.net (external link)
"You don't know how far you can go, untill you've gone too far."
Mark_Cohran
Joined Jul 2002
Aug 29, 2008 15:58 |  #3
I haven't experienced the problem, but it sounds like an electrical circuit malfunction in the camera remote socket.
Mark
Some primes, some zooms, some Ls, some bodies and they all play nice together.
Forty years of shooting and still learning.
My Twitter (external link) (NSFW)
Follow Me on Instagram (external link)
rayatphonix
Aug 29, 2008 16:37 |  #4
The Canon cable release button is RS-80N3. The remote switch for the old film EOS cameras won't work (at least the one for my EOS-1).
I've not had the problems with my remote switch you described, and I've used mine alot. This remote has a lock button (running lock). As you push the grey button you can accidently slide the button assembly forward and lock the button in the "pressed" mode. Is the shutter on the camera staying open or are you unable to take the next photo because the camera thinks the shutter is already pressed? If it's the latter, the running lock may be engaging.
1,229 views & 0 likes for this thread, 4 members have posted to it.
2674 guests, 168 members online
