Is there a 1.4 or 2X converter for my Canon 75-300 Lens? Is it even worth it? I realize I'd be stuck around f11 but I want to go beyond 300mm without alot of money.
eForce Member 51 posts Joined Mar 2008 More info | May 10, 2008 23:22 | #1 Is there a 1.4 or 2X converter for my Canon 75-300 Lens? Is it even worth it? I realize I'd be stuck around f11 but I want to go beyond 300mm without alot of money. Knowledge can be the Absence of Creativity.
yogestee "my posts can be a little colourful" More info | May 10, 2008 23:25 | #2 eForce wrote in post #5500436 Is there a 1.4 or 2X converter for my Canon 75-300 Lens? Is it even worth it? I realize I'd be stuck around f11 but I want to go beyond 300mm without alot of money. Check out the Tamron AF SP 1.4X TC (the white model).. One of the best TCs on the market.. Jurgen
asysin2leads I'm kissing arse 6,329 posts Likes: 3 Joined Dec 2006 Location: Lebanon, OH More info | I'm a schmuck and typed the wrong thing. Woolburr had my back on this one. Kevin
Woolburr Rest in peace old friend. 66,487 posts Gallery: 115 photos Best ofs: 2 Likes: 143 Joined Sep 2005 Location: The Tupperware capitol of eastern Oregon...Leicester, NC! More info | May 11, 2008 02:06 | #4 asysin2leads wrote in post #5500989 Do not quote me on this, but I think that the Kenko extension tubes are compatible. However, it might not be worth the hassle. Extension tubes are not Teleconverters. Extention tubes are used to reduce the minimum focus distance, essentially turning a lens into a macro lens. There is no glass in a tube. People that know me call me Dan
asysin2leads I'm kissing arse 6,329 posts Likes: 3 Joined Dec 2006 Location: Lebanon, OH More info | May 11, 2008 02:49 | #5 Woolburr wrote in post #5501017 Extension tubes are not Teleconverters. Extention tubes are used to reduce the minimum focus distance, essentially turning a lens into a macro lens. There is no glass in a tube. I knew that. It's late here at work and typed the wrong thing. Thanks for clearing that up. Kevin
condyk Africa's #1 Tour Guide 20,887 posts Likes: 22 Joined Mar 2005 Location: Birmingham, UK More info | May 11, 2008 02:56 | #6 I wouldn't personally even bother. Trying to MF such a slow lens in a small dark viewfinder when the starting image quality isn't really there much of the time seems a futile endevour. The Kenko Pro 1.4x would probably fit too. The Canon or Sigma ones won't. https://photography-on-the.net …/showthread.php?t=1203740
| Latest registered member is johntmyers418 1079 guests, 147 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
