Anybody know what type of plug end you need for a cable for skyport to vivitar 283?
Already made my own cables with Pc female ends and trigger it with a optical trigger but would like to make one and get rid of the optical trigger.
Sgt. Senior Member More info | May 11, 2008 16:02 | #1 Anybody know what type of plug end you need for a cable for skyport to vivitar 283? Iain
May 11, 2008 16:05 | #2 The Skyport has a 3,5mm jack output. ----- Bernt-Inge -----
Thanks I know that end, I need to know what the vivitar end is for the 283. Iain
SolidxSnake Goldmember 1,656 posts Likes: 2 Joined Nov 2007 More info | May 11, 2008 16:32 | #4 The vivitar connector is a proprietary connector. Troubleshooting 101 (see also: LightRules,perryge):
Thanks that looks like an option but at this point I would rather try to make my own cable. Iain
SolidxSnake Goldmember 1,656 posts Likes: 2 Joined Nov 2007 More info | May 11, 2008 18:16 | #6 Sgt. wrote in post #5504070 Thanks that looks like an option but at this point I would rather try to make my own cable.
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | May 11, 2008 19:16 | #7 I just opened up a Sunpak 383 and added my own connector - 3.5mm mono socket. It was dead easy, I suspect the vivitar would be the same. Just drill a hole, insert wires, and solder your wires on. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
SolidxSnake Goldmember 1,656 posts Likes: 2 Joined Nov 2007 More info | May 11, 2008 19:40 | #8 tim wrote in post #5504596 I just opened up a Sunpak 383 and added my own connector - 3.5mm mono socket. It was dead easy, I suspect the vivitar would be the same. Just drill a hole, insert wires, and solder your wires on.
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | May 11, 2008 19:48 | #9 SolidxSnake wrote in post #5504710 Three wires for the vivitar. The jack is switched. When there is nothing plugged into the jack, the + from the sync circuit in the flash goes to the center pin of the hotshoe. When something is plugged into the connector of the flash, the + only goes to the tip of the connector that is plugged in, and not to the center of the hotshoe. The Sunpak has 3 wires too, the ones I connected to worked when there was nothing in the 2.5mm jack, and since I don't plan to use the jack I didn't test with anything plugged in. Good tip though, I wondered why there was an extra wire. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
After researching a bit on the web. This looks like the way to go.What would you suggest, a 2.5 mm plug and socket? Iain
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | May 11, 2008 20:14 | #11 3.5mm is more standard I think. If you wanted to get fancy you can even add a proper socket to the flash shoe, but I just drilled a hole. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
I just figured they were smaller, save some space trying to squeeze it in. Iain
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | May 11, 2008 20:45 | #13 If you're mounting it inside the shoe then sure, 2.5mm will be easier. I did it the easy way...
Where did you solder those wires? That sync port? wires to hotshoe? Iain
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | May 11, 2008 21:29 | #15 I soldered the black wires in, to the existing sync port. I could've connected them to the hotshoe connectors too, they're all connected together. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
| Latest registered member is semonsters 922 guests, 118 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
