I have ab800 bought 2 softbox's from amvoma but they are to heavy for lights how can i connect them to the light stand instead of the ab any suggestions because the lightbox's are great.
bartlett714 Mostly Lurking 16 posts Joined Dec 2006 More info | May 11, 2008 21:18 | #1 I have ab800 bought 2 softbox's from amvoma but they are to heavy for lights how can i connect them to the light stand instead of the ab any suggestions because the lightbox's are great.
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | May 11, 2008 21:55 | #2 That's a long mixed up sentence, it's quite hard to read. How about telling us what stands you have, and how you current connect everything together. You have a speed ring? Any heavy duty light stands will be fine, I have 13' impact stands. I'd probably buy another brand next time, these ones are a bit fiddly to adjust the feet. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
May 11, 2008 22:08 | #3 I have ab 13ft heavy duty stands. I currenty use the speed rings that came with the amvona softboxs. The problem is not the stand but the light ring wont stay on the light very good.
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | May 11, 2008 22:57 | #4 Sounds like you need another speedring to me. I have the AlienBees speedring and it works fine. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
Lotto Goldmember 2,750 posts Likes: 192 Joined Mar 2005 Location: Southern California More info | May 11, 2008 23:09 | #5 The amvona's speedring has a larger opening than the AB's. If you are handy with a hacksaw, cutting part of the ring off will fit the AB strobe. 5D, 24-105L, 70-200L IS, 85mm Art, Godox
May 11, 2008 23:50 | #6 Iwill try that if not is there anyway to hook them directly to the light stand
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | May 12, 2008 00:17 | #7 Light modifiers are attached to lights, not stands. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
form "inadequately equipped" 4,929 posts Likes: 13 Joined Jan 2006 Location: Henderson, NV More info | May 12, 2008 18:25 | #8 I modified my amvona speedring with drill and file to make holes the alienbees hooks fit in. Las Vegas Wedding Photographer: http://www.joeyallenphoto.com
| Latest registered member was a spammer, and banned as such! 2441 guests, 105 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
