Krank wrote in post #5507277
Mainly architecture and scenic views. In most cases I am thinking well lit situations, except for night shooting which in that cans I would be using a tripod. Guess I am answering my own question here. PS This forum is awesome, lots of responses and no sarcasm for a new guy wanting to spend his money. Thanks. I have both, and I used them on the 40D.
I use the 17-55 for company events, coupled with my flash. The 2.8 makes things easier at low-light, and when some portraits are needed. Being said that, 17-40 is still sufficient for events with a flash. This is just personal preference.
But for landscape, I use the 17-40. I can't imagine removing the filter on 17-55, allowing chance for dust to be trapped in the lens, to use my GND filters. And I cannot imagine not bringing my GND filters for scenic shots.
Even though 17-55 has some barrel movement when zooming, it is still reasonably light and managable; maybe because I hold the 70-200 quite a lot but it never seems to be a problem. 17-40 is lighter though, and the build seems to be able to take more knocks than my 17-55.
I don't think you'll go wrong with any of them. But if u're going more on landscape / scenic, probably would advise you to take the 17-40. And if u are craving for a 5D or FF in future, 17-40 makes an ideal wide angle lens (only losing 1mm against 10-22).
Well, it's ur budget and you have to decide what you're going to use it for. But here's some sharing for you. Hope it helps.
