Thread started 12 May 2008 (Monday) 08:22
busy......slow flash?
tomdlgns
May 12, 2008 08:22 |  #1
i was in a low light scenario last night and it seemed that i could only take 1 or 2 pictures before my xti was displaying busy on the screen, i was using the flash.
i sometimes i had to wait 10-15 seconds for the busy light to go away. it was at a graduation ceremony, so everyone is in a hurry trying to take pictures and all that good stuff...
would an alternative flash help me in this situation? i realize it will kill my battery quicker than the on board flash, but this is something that needs to be addressed.
thanks
none
shutterfiend
May 12, 2008 08:38 |  #2
Not sure if I understood this right. Were you using the pop-up flash?
External flashes have their own batteries. Some external flashes recycle faster than others. Recycle time for external flashes are usually faster than the pop-up. Recycle time depends on exposure.
https://photography-on-the.net …p=7812587&postc​ount=91776
Curtis ­ N
Master Flasher
May 12, 2008 08:39 |  #3
Hotshoe-mounted flash units use their own batteries (inexpensive AA), so using one will help your camera's battery last longer than if you were using the built-in.
There are many factors affecting recycle time, but most hotshoe flash units will recycle faster than the built-in unit, given the same output.
Here's six more reasons to get a good flash unit.
tomdlgns
May 12, 2008 08:43 |  #4
i was using the pop up flash, correct.
also, i have the battery grip ordered, ordered it last week, so if i did get an extra flash, battery life wouldn't be that great of a concern. i just want to be able to take 3-5 pictures within 15-30 seconds. i hated waiting the additional 10-15 seconds between some of the pics for the flash to recycle. also, i don't want to carry a battery pack and a big flash either. just something that can fit on top of the camera is what i am hoping will help me out.
none
tomdlgns
May 12, 2008 08:44 |  #5
shutterfiend wrote in post #5507549 (external link)
that explains why i had a shorter delay during some pictures and a longer delay during other pictures. i was going to ask that question, but now i see where you are getting at.
thanks
none
elysium
"full of stupid banter"
Location: Harrow/London/UK/GB/That Part Of The World/Next To France
May 12, 2008 08:45 |  #6
tomdlgns wrote in post #5507573 (external link)
Thats normal. Using a battery grip will not help much. It comes up busy not just for recycling but to stop the flash from burning out.
Everyday, a programmer finds a way of creating an idiotproof program. Everyday, the universe spits out another idiot.....So far, the universe if winning
tomdlgns
May 12, 2008 08:47 |  #7
elysium wrote in post #5507585 (external link)
sure, that is a good point.
but what i meant about the battery grip..if the flash also drains the battery a little more, i will be able to squeeze in mroe shots if i have the battery grip, correct?
i realize this will not help the recycle time, i just figured i would be able to get more shots in before i had to replace the batteries.
thanks.
none
elysium
May 12, 2008 08:50 |  #8
tomdlgns wrote in post #5507596 (external link)
thanks.
Maybe be able to squeeze more shots out of it with extra mattery but in all honesty, you sound like you need faster recycle times and adequate light. Thought about a 580EX?
shutterfiend
May 12, 2008 08:52 |  #9
External flashes may take anywhere between 0.1 sec to 6 sec or more to recycle. Before you make a purchase it might be a good idea to read some of the material on this forum. Just follow the link CurtisN provided, it offers great in depth understanding about lighting. "Master Flasher" is not a tittle to be taken lightly. He does flash a lot ;)
tomdlgns
May 12, 2008 08:53 |  #10
elysium wrote in post #5507606 (external link)
what is mattery?
yes, a 580EX was something i was looking at, however, i didnt want to buy if if the recycle times are not greater.
back to the battery issue.
if i have a 580ex with my standard canon battery, lets say i get 1000 shots, assuming i use the flash on all the shots.
wouldnt i get 2000 pictures with the battery grip while using the 580ex flash?
those are not exact numbers, obviously, that is how i thought it worked.
thanks.
none
tomdlgns
May 12, 2008 08:57 |  #11
shutterfiend wrote in post #5507625 (external link)
yes, i would like more information, that is why i didn't just run out and buy a flash without getting more information.
another thing i want to point out...there is only so much i can do for lighting in this particular situation, a hectic/crowded auditorium hall. since i don't have much control over the lighting, maybe a point and shoot has a better built in flash?
i saw many people taking pic after pic after pic with their tiny point and shoot, while i had to wait 10 seconds for a recycle, at times.
good advice so far, thanks guy.
none
elysium
May 12, 2008 08:59 |  #12
tomdlgns wrote in post #5507629 (external link)
what is mattery?
thanks.
I meant battery sorry lol. You could get more or less depending on the power required for the shots. You just have far more control over light used.
Like mentioned already, recycle times are faster.
tomdlgns
May 12, 2008 09:00 |  #13
elysium wrote in post #5507664 (external link)
ok, thanks.
none
tim
Light Bringer
May 12, 2008 09:02 |  #14
Get a used 580EX or 550EX and a Canon CP-E3 or CP-E4 battery pack. It'll recharge near enough to instantly, so long as you use ISO400 to 800 - and there's no good reason not to. A full charge is 2-3 seconds, but lots of full power flashes and you'll burn out the flash head. The 430EX would be a good cheaper solution, it doesn't take a battery pack but it'll still recharge a lot quicker than your built in camera flash.
shutterfiend
May 12, 2008 09:04 |  #15
tomdlgns wrote in post #5507651 (external link)
This is probably not true. However, your camera might allow you to use settings that require greater flash output and hence longer recycle times. Ordinary point and shoots might limit flash output for better recycle time.
2,367 views & 0 likes for this thread, 6 members have posted to it.
2591 guests, 167 members online
