Does the Pocket Wizard support ETTL? If not, is there a wireless radio flash trigger that does?
Ovi
OviV Goldmember 1,129 posts Joined Oct 2003 Location: Miami, FL More info | Dec 13, 2004 09:07 | #1 Does the Pocket Wizard support ETTL? If not, is there a wireless radio flash trigger that does? 5D, 40D, Sigma 12-24mm f/4.5-5.6 EX, Sigma 15MM Fisheye,17-40 L, 24-105 L, 50 1.8, Tamron 28-75 2.8, Sigma 70-200 2.8, 70-300mm f/4-5.6 IS, 100-400 L, 300 F4 L, 580 ex, Sigma 500 Super DG Flash x 2, too much other stuff to list.
scottbergerphoto Cream of the Crop 5,429 posts Likes: 1 Joined Jun 2003 Location: Brooklyn, NY, USA More info | Dec 13, 2004 10:11 | #2 No. Pocket Wizard is an on/off deal. Canon's proprietary ETTL/ETTLII uses a series of light pulses. If you go Pocket Wizard, you are using manual flash. I believe your only options are to use an STE2 or a 550 or 580EX as Master to use ETTL/ETTLII. One World, One Voice Against Terror,
robertwgross Cream of the Crop 9,462 posts Likes: 3 Joined Nov 2002 Location: California More info | To put it another way, the Pocket Wizard carries across sync only.
dennykyser Senior Member 983 posts Likes: 3 Joined Jan 2004 Location: Wentzville, Mo More info | Robert and Scott answered your questions but I want to add dont be afraid of Manual Settings. A light meter is a wise investment and gives you much more control. I have become a better photographer by giving up ETTL IMO.
Sometimes when shooting events it is difficult to find the time to do meter readings. This is where ETTL comes in handy. It allows me to take the shot and be pretty close most of the time. I would love to have a remote flash for fill in a lot of times while keeping ETTL. I am under the impression that the Canon Wireless system requires that the remote flash be "visible" to the master flash since it is Infrared. Is this true? 5D, 40D, Sigma 12-24mm f/4.5-5.6 EX, Sigma 15MM Fisheye,17-40 L, 24-105 L, 50 1.8, Tamron 28-75 2.8, Sigma 70-200 2.8, 70-300mm f/4-5.6 IS, 100-400 L, 300 F4 L, 580 ex, Sigma 500 Super DG Flash x 2, too much other stuff to list.
robertwgross Cream of the Crop 9,462 posts Likes: 3 Joined Nov 2002 Location: California More info | Yes, trying to use an external meter and then set up a shot, then get another pose, then repeat the whole process ... that can get frustrating during a wedding. In general, when I shoot a wedding, I will check my histogram each time we move to a new location, and otherwise I just let the flash do its thing without fooling around. The film shooter generally does one external meter reading at each location, just to make sure he has it right, but there isn't that much fluctuation between different poses or different groupings. The external meter can help you figure out the ambient light balance against the flash.
Thanks Bob. I'll have to do some experimenting. 5D, 40D, Sigma 12-24mm f/4.5-5.6 EX, Sigma 15MM Fisheye,17-40 L, 24-105 L, 50 1.8, Tamron 28-75 2.8, Sigma 70-200 2.8, 70-300mm f/4-5.6 IS, 100-400 L, 300 F4 L, 580 ex, Sigma 500 Super DG Flash x 2, too much other stuff to list.
robertwgross Cream of the Crop 9,462 posts Likes: 3 Joined Nov 2002 Location: California More info | It's not the sort of experimenting that you would need that big Sigma lens for!
No that one is for capturing images like the one in my Avatar. I'm going to try putting my Sigma 500 DG Super flashes at different angles to each other to try getting them to fire. I will do this test outside so I know no bouncing is happening and this should tell me what angles I will be able to use. 5D, 40D, Sigma 12-24mm f/4.5-5.6 EX, Sigma 15MM Fisheye,17-40 L, 24-105 L, 50 1.8, Tamron 28-75 2.8, Sigma 70-200 2.8, 70-300mm f/4-5.6 IS, 100-400 L, 300 F4 L, 580 ex, Sigma 500 Super DG Flash x 2, too much other stuff to list.
| Latest registered member was a spammer, and banned as such! 2241 guests, 126 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
