I'm planing to buy the 70-200L f4 soon, I just wondering that I can mount the body (Canon 10D) to the tripod with the len on or I have to use the tripod ring?
walkien Senior Member 938 posts Likes: 1629 Joined Sep 2003 Location: West Covina, CA More info | Dec 13, 2004 10:25 | #1 I'm planing to buy the 70-200L f4 soon, I just wondering that I can mount the body (Canon 10D) to the tripod with the len on or I have to use the tripod ring? Canon 1D Mark II N, Canon 5D Mark II with grip, Canon 7D II with grip, Canon 10D with grip, broken Canon G2. 28-135 mm IS, 50 mm F1.8 II, 24-70 f2.8L, 70-200 f2.8L IS, 70-200 f4 L, 85 f1.8, 100 macro 2.8 IS
phili1 Senior Member 891 posts Joined Oct 2003 Location: Paramus N.J. More info | Dec 13, 2004 10:40 | #2 you can but you put stress on the camera mounting ring. You get better balance from the lens ring mount. MKII N-Canon 20D - Tamron 90MM F2.8 Macro -
flyfishnj Senior Member 363 posts Joined Sep 2003 Location: NJ More info | That lens (70-200 f4) weighs only 1.56 lbs. Probably won't put too much weight on the lens mount. Whereas the 100-400 weighs 3 lbs. and the 70-200 f2.8 IS weighs 3.2 lbs. ~John~
CoolToolGuy Boosting Ruler Sales 4,175 posts Joined Aug 2003 Location: Maryland, USA More info | The tripod ring is nice to have, but not required, as mentioned above. However, there are two things you should note:
Have Fun, Rick
RichardtheSane Goldmember 3,011 posts Likes: 3 Joined Jun 2003 Location: Nottingham UK More info | phili1 wrote: you can but you put stress on the camera mounting ring. You get better balance from the lens ring mount. I disagree with you here. If in doubt, I shut up...
Sketcher Senior Member 513 posts Joined Apr 2003 Location: Minnesota More info | I've used the 70-200 f/4 with and without the tripod ring. It is what it is...
walkien THREAD STARTER Senior Member 938 posts Likes: 1629 Joined Sep 2003 Location: West Covina, CA More info | Thank you for all the quick reply, my 70-200L lens will be delivered on Wednesday, I'm so excited. Canon 1D Mark II N, Canon 5D Mark II with grip, Canon 7D II with grip, Canon 10D with grip, broken Canon G2. 28-135 mm IS, 50 mm F1.8 II, 24-70 f2.8L, 70-200 f2.8L IS, 70-200 f4 L, 85 f1.8, 100 macro 2.8 IS
DaveG Goldmember 2,040 posts Likes: 1 Joined Aug 2003 Location: Dartmouth, Nova Scotia More info | Dec 13, 2004 18:01 | #8 walkien wrote: I'm planing to buy the 70-200L f4 soon, I just wondering that I can mount the body (Canon 10D) to the tripod with the len on or I have to use the tripod ring? I use a 70-200 f2.8 with a motordrive and the tripod collar. But I'd love to have a tripod collar on EVERY lens that I own if it was possible. To flip from horizontal to vertical is so easy if the lens/camera is on a monpod or tripod. And although the 70-200 f4 is a lot lighter than the f2.8, that lens + the vertical grip and the camera body is NOT light and you will be much more comfortable with it all on a monopod and the tripod collar sure lends itself to that use. "There's never time to do it right. But there's always time to do it over."
eric1 Senior Member 729 posts Likes: 32 Joined May 2003 Location: St. Louis, Mo. More info | RichardtheSane wrote: I disagree with you here. Since the 10D (without grip) is heavier than the 70-200 F4L then using the tripod ring will not put less stress on the lens mount. Either way with the weight involved the lens mount will not be affected. Richard is right, but iv'e found the ring helps me get more keepers. i usualy use it with a monopod, and i get less shake with the ring.
phili1 Senior Member 891 posts Joined Oct 2003 Location: Paramus N.J. More info | Richard you are entitled to have your opinion but let me give you an example. Hold a four pound weight in your hand and hold your hand straight out for four hours and then tell me there is no stress. In the old days they were few and far in between but the collar evolved because of the wear on mounting rings due to there weight. MKII N-Canon 20D - Tamron 90MM F2.8 Macro -
CoolToolGuy Boosting Ruler Sales 4,175 posts Joined Aug 2003 Location: Maryland, USA More info | RichardtheSane wrote: I disagree with you here. Since the 10D (without grip) is heavier than the 70-200 F4L then using the tripod ring will not put less stress on the lens mount. Either way with the weight involved the lens mount will not be affected. As mentioned before, the 70-200 f4L should not be a problem without the tripod ring. Rick
RichardtheSane Goldmember 3,011 posts Likes: 3 Joined Jun 2003 Location: Nottingham UK More info | OK, Maybe I should have been a little clearer first. If in doubt, I shut up...
| Latest registered member was a spammer, and banned as such! 2259 guests, 137 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
