Thread started 12 May 2008 (Monday) 12:06
Weird thingy
Cr4zYH3aD
May 12, 2008 12:06 |  #1
Yesterday on tv there was a documentary, and the photographer had a separate plastic thingy that was reading available light and would tell what to use for the picture (1/250, F4) etc.
Do you have an idea of what it is and how much it cost ?
Canon EOS 7D | Canon EF 100mm f/2.8L Macro IS USM
Jon
Joined Jun 2004
May 12, 2008 12:09 |  #2
It's called a light meter, and how much are you willing to spend?
http://www.bhphotovide​o.com …ssories_Light_M​eters.html (external link)
Jon
Cocker Spaniels
blonde
Buck Naked Floozies
May 12, 2008 12:09 |  #3
you mean a light meter?
http://sekonic.com/mai​n/ (external link)
Cr4zYH3aD
May 12, 2008 12:13 |  #4
yeah, that's it ! thanks alot. It looks really useful
Pasukun
May 12, 2008 12:13 |  #5
Gawd.. this is one of the most controversial equipment for me..
I almost pulled a trigger on one.., but I could not help but think "Is it worth more than buying another lens?".
I see the benefit of owning one.., but I guess I need some more convincing.. :confused:
"the things we touch have no permanence.. as there is nothing we can hold onto in this world.. only by letting it go can we truly possess what is real.."
My Gears
RandyMN
May 12, 2008 12:34 |  #6
I find the the incident light meter as indespensible for doing studio flash photography. Sure some will say they just eye it then take a test shot, but I like the meter route and actually have two of them. I also like the spot meter for reading various reflected light values.
I won't try to convince anyone else how to read light or what to do with their money.
Curtis ­ N
Master Flasher
May 12, 2008 12:38 |  #7
Pasukun wrote in post #5508835 (external link)
If you're using manual flash, yes.
Titus213
May 12, 2008 12:43 |  #8
You have a pretty decent meter in your camera for ambient light. Shooting studio flash is a different story and a meter is quite useful - again, not necessary. I have one and use it almost exclusively for studio light setup.
Dave
Perspiring photographer.
Pasukun
May 12, 2008 13:12 |  #9
Curtis N wrote in post #5508967 (external link)
Well.. I do use manual flash alot. So I can definitely benefit from it.
One of the reason wanting it is.. because of this article (external link).
And I absolutely hate to blow out the highlight.
My Gears
boyderic
May 12, 2008 14:34 as a reply to  @ Pasukun's post |  #10
I spent Saturday morning shooting second camera with a local pro. I've known him for years, and wanted to shadow him while I transition to the DSLR scene. When I first met him, years ago, his light meter was always out, and constantly referred to. It didn't come out once on Saturday. A test shot or two, and a review of the histogram, and he was good to go. We were both on location and in studio. I still like a second opinion myself though. I prefer to get it as close as possible out of the camera, and not rely on post-processing in RAW. A light meter will help you nail the exposure. I shoot an EOS 1D classic, and the highlights are easy to blow if I'm not careful.
Bamamike
May 12, 2008 19:13 as a reply to  @ boyderic's post |  #11
Using the histogram (not available in film cameras) and the function that shows you overblown areas is an accurate light metering system. Why wasting money on a measuring system you can make other mistakes with? Your cam is quite accurate, using manual and make one or two test shots, that's it.
Two bodies left, some "soso" lenses, and still a lot of gear.....
Curtis ­ N
Master Flasher
May 12, 2008 20:04 |  #12
Bamamike wrote in post #5511558 (external link)
Not even close.
I can and do use my histogram in situations where use of an incident meter isn't possible or practical. It's a valuable tool, but to refer to it as an accurate metering system is simply false.
Histograms also require experience to interpret properly. And when the clipped areas are small, they're easy to miss, especially if you're trying to look at that thing in bright sunlight.
After about 40,000 shots, I can usually get pretty close with histogram evaluation. But when I'm getting paid to make pictures, "usually pretty close" isn't good enough. Incident metering, when practical, is also faster than the "test, chimp, adjust" method. My meter is one of the best investments I've ever made.
If you don't have a meter, a good calibration target can improve the accuracy of the histogram method tremendously. I like these that Ed Pierce sells (external link).
Here's an example of histogram-based metering gone wrong.
PacAce
Joined Feb 2003
May 12, 2008 21:33 |  #13
Curtis N wrote in post #5511847 (external link)
Not even close.
+1 :)
...Leo
1,231 views & 0 likes for this thread, 10 members have posted to it.
Weird thingy
2596 guests, 166 members online
