I was redirected to this forum to seek help on a problem that I'm having. I'm currently using an Xti with a Sunpak Digiflash 2800 to try to photograph Hummingbirds. The flash works great for brightening up the shot, but I can't seem to get good shots that aren't blurred due to the speed of the bird / wings. Is it possible to use this set up to get a good enough shutter speed for Hummingbirds?
So far I've tried to set the Flash Sync. Speed in A/V to Auto, but it doesn't seem to be working. I'm not sure if it's my error in trying to set it up or if it's because these two pieces of equipment can't work together. Any ideas?
You can see the full story and some example shots in the original thread...
https://photography-on-the.net/forum/showthread.php?t=501517
You know, it never dawned on me that it may be camera shake! These were all handheld. Guess I'll have to give a tripod a go to see if that helps.
