Hello All,
Could you please suggest Flash units that can be used on XTI, cheap and premier ones.
mangaloreaviators Senior Member 387 posts Joined Nov 2007 More info | May 12, 2008 21:41 | #1 Hello All,
CorzyPhoto Senior Member 748 posts Likes: 1 Joined Apr 2008 Location: South FL More info | May 12, 2008 22:15 | #2 |
CurtisN Master Flasher 19,129 posts Likes: 11 Joined Apr 2005 Location: Northern Illinois, US More info | May 12, 2008 22:22 | #3 There is no Canon 480EX Speedlite. "If you're not having fun, your pictures will reflect that." - Joe McNally
alduin Senior Member 915 posts Likes: 1 Joined Jan 2008 Location: Lehigh Valley, PA More info | May 12, 2008 22:26 | #4 The sticky PacAce put together has links to a few posts that give a really good overview of which flash is right for you. I found it quite helpful. 7D+BG-E7 | 5D | G9 | 24-70 f/2.8L | 70-200 f/2.8L IS | 100-400L IS | 10-22mm | 50mm f/1.4 | 580EX II | 430EX II | YN565EX
billrhea Member 172 posts Joined Jan 2008 More info | May 12, 2008 23:19 | #5 I just got the 430ex from best buy open box for $220 and OMG what a difference. Indoor shots are so much better. Canon 5d Mark II
mismis Member 181 posts Joined Feb 2008 More info | Sorry to threadjack, but a quick question: Xti + grip + RRS L-Bracket || RRS clamp + Markins M-20 + Gitzo 1345 || Kit Lens + 50mm f1.8 + 24-105L + 35L + 70-200L f2.8 IS
DLInspire Member 227 posts Joined Dec 2007 More info | You cannot trigger a flash to go off with the XTi or any other camera(by itself) when the flash is off the hotshoe. Powershot SD 400
mismis Member 181 posts Joined Feb 2008 More info | Hmm... Im thought I'd seen this in a video somemore before. Xti + grip + RRS L-Bracket || RRS clamp + Markins M-20 + Gitzo 1345 || Kit Lens + 50mm f1.8 + 24-105L + 35L + 70-200L f2.8 IS
May 13, 2008 05:09 | #9 DLInspire wrote in post #5513293 You cannot trigger a flash to go off with the XTi or any other camera(by itself) when the flash is off the hotshoe. nikon does R5, RF 85 f1.2L, RF 50 f1.8, 6D, EF16-35 F4L IS, EF50 f1.4, EF 100 f2.8 L Macro IS
elysium "full of stupid banter" 11,619 posts Likes: 1 Joined Jul 2007 Location: Harrow/London/UK/GB/That Part Of The World/Next To France More info | May 13, 2008 05:44 | #10 For XXXD bodies without grip or small hands and everyday use, 430EX will be enough. If you need more power, think about a 550EX or 580EX. Everyday, a programmer finds a way of creating an idiotproof program. Everyday, the universe spits out another idiot.....So far, the universe if winning
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | May 13, 2008 05:48 | #11 You only get an extra stop or so moving from the 430 to the 580, the main reason to go for the 580 would be features. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
martinsmith Senior Member 680 posts Joined Jul 2007 Location: S Glos, UK More info | May 13, 2008 06:49 | #12 mismis wrote in post #5513284 Sorry to threadjack, but a quick question: Can the xti be used to trigger external flashes as a master? If you use cheap optical slaves then this is an option. You only have manual power though (no ETTL). [SIZE=1]ms-imaging
Shooting Goldmember 1,552 posts Likes: 3 Joined Jan 2008 More info | Promaster 7500DX, has a module made just for the XT/XTI..
| Latest registered member was a spammer, and banned as such! 2591 guests, 167 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
