Thread started 13 May 2008 (Tuesday) 10:51
STROBES...Max Shutter Sync
Matt30D
May 13, 2008 10:51 |  #1
What is the Max shutter sync for studio strobes???
www.schuldtimagery.com (external link)
Gear: 5D/5DII/30D
Lens: 28-75, 85 1.8, 70-200 2.8 IS, 50 1.8, 17-40L
René ­ Damkot
May 13, 2008 11:05 |  #2
Depends on camera, strobe and triggering method used.
Mostly somewhere in the 1/60 to 1/250s range.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
Matt30D
May 13, 2008 11:07 |  #3
I am using the 30D in Manual triggering with the 580EX...also in manual.
Gear: 5D/5DII/30D
evolved
May 13, 2008 11:09 |  #4
Matt30D wrote in post #5515602 (external link)
max sync for the 30D is 1/250. using wireless triggers you can still get 1/250, but it could be sketchy at times.... I usually shoot @ 1/160 just to be on the safe side, unless I need the extra SS to stop down the ambient light.
Curtis ­ N
Master Flasher
May 13, 2008 11:29 |  #5
By that I'm assuming you're triggering the strobes via their built-in optical slaves, using the 580EX as the master/triggering device. Usually you won't have a problem at 1/250.
But some strobes such as the Elinchrom D-Lites have a relatively long flash duration, which will require you to slow down the shutter a little bit, to make sure the strobe is done firing before the second shutter curtain begins to close.
With studio strobes, the flash duration is actually longer at low power settings (the opposite of hotshoe flash units). So a shutter speed that works ok at full power may be a bit too fast at 1/32 power.
René ­ Damkot
May 13, 2008 11:43 |  #6
Curtis N wrote in post #5515742 (external link)
Eeehm.. What?
Not any studio strobe I've used... Lower power setting = shorter flash duration.
From here (external link): "Even at full power (1200J) the flash discharge lasts no longer than 1/500 second at t.0.1, 1/1500s when measured at t.0.5. When set to 300J the flash duration drops to 1/1200s when measured at t.0.1 and 1/3500s at t 0.5"
PacAce
Joined Feb 2003
May 13, 2008 11:45 |  #7
René Damkot wrote in post #5515831 (external link)
Eeehm.. What?
Yes, I agree. It depends on the design of the strobes. Some have longer flash durations at full power and other at minimum power.
...Leo
Curtis ­ N
Master Flasher
May 13, 2008 12:00 |  #8
Flash duration explained:
http://www.paulcbuff.c​om/forums/viewtopic.ph​p?t=59 (external link)
Info on Alienbees flash duration (second table down):
http://alienbees.com/s​pecs.html (external link)
White Lightning:
http://www.white-lightning.com/specs.ht​ml (external link)
René ­ Damkot
May 13, 2008 12:12 |  #9
Curtis N wrote in post #5515939 (external link)
White Lightning:
Hehehe. Never used those brands...
I do know that Broncolor and ProPhoto work different ;)
Curtis ­ N
Master Flasher
May 13, 2008 12:15 |  #10
René Damkot wrote in post #5516025 (external link)
I do know that Broncolor and ProPhoto work different.
They work differently on your wallet, too. ;)
My original statement may have been a bit too generalized, but I think it's valid for entry-level or mid-priced strobes.
René ­ Damkot
May 13, 2008 13:36 |  #11
Curtis N wrote in post #5516049 (external link)
True ;)
From the first link you gave, I'd say the actual flash duration would stay the same with those units though, and only the t 0,5 would change, (voltage lower, so the "peak" gets lower, but not longer in total) would you agree?
I'd suppose the more expensive units I mentioned use capacitor switching.
(I do know that the *real* expensive Broncolor Graphite series also have the ability to alter the flash duration. No idea how they do that ;))
DC ­ Fan
May 13, 2008 14:10 |  #12
With a Rebel 300D and a pair of SP Excalibur 3200 monolights, the bottom edge of the frame is starting to go slightly dark at 1/250. Of course, that's no reason to toss out the lights. :)
PacAce
Joined Feb 2003
May 13, 2008 14:13 |  #13
The Dyna-lite Uni250R ($515.00) has full power duration of 1/1800 and 1/8 power duration of 1/6250. The Uni400JR ($638.00), FP duration = 1/675, 1/8 P duration = 1/2200. Both of these models would not be what I consider high end models. :)
...Leo
1,406 views & 0 likes for this thread, 6 members have posted to it.
2591 guests, 167 members online
