Thread started 13 May 2008 (Tuesday) 18:13
cheap flash for newbie
thekid17
May 13, 2008 18:13 |  #1
I need a cheap flash since im low on money right now. i was thinking about the sunpak 383. but can that fit on the camera or must that be off the camera?
Ty ­ G
May 13, 2008 23:18 |  #2
It can fit on the camera; but in all honesty, you will be disappointed. It does not have ETTL, so you will have to guess at a few shots to get exposure or get a flash meter. If you get a flash meter and a $80 sunpak 383, you will end up coming close to the price of the 430 canon flash with ETTL. I've gone the sunpak route with cactus triggers; and it is OK if you are shooting portraits where someone is sitting still in the same light for all the shots. But if you want to shoot in room for a birthday party or a wedding with changing light everywhere you aim, the sunpak will only dissappoint you and will have you chasing answers.
cito17
May 13, 2008 23:43 as a reply to  @ Ty G's post |  #3
Look into a Sigma EF-500 DG Super, Sigma EF-530 DG ST or Super, used 380EX, 420EX, or 550EX. All of those are ETTL.
-Adrian [ Flickr ] (external link)[ Tumblr. ] (external link)[Full Gear List]
[ EOS 5D III|EOS 30D|Canonet QL17 G-III|Olympus OM-1|Rolleiflex MX-EVS|Leica M2 ]
ninext
May 14, 2008 06:39 |  #4
Ty G wrote in post #5520079 (external link)
if you have a basic understanding of how flash exposure works the sunpak 383 will be more than worth the $80.
when i'm indoors, i pick a power output based on how much light i think i'll need. i set the iso to 100-400; again, depending on how dark the room is. stick the camera on manual mode and take two or three test shots.
takes 5-10 seconds, but you only really have to do it once.
not saying ETTL is worthless, i just dont see manual flash as being that much of a hurdle. especially when a sunpak 383 costs 1/4th the price of a 580exII.
gear list
Jim ­ M
May 14, 2008 12:26 |  #5
I think the 383 does have an automatic feature. It just does it the old fashioned way, namely with a sensor on the flash itself rather than using the camera for through-the-lens flash sensing. You won't have to use manual flash for everything, but the camera and the flash won't talk to each other about the exposure. It's all on what the flash sees. I (and many, many others) used this style of flash for years and years. It will work very well in most situations and you only have to do a little bit of thinking.
DC ­ Fan
May 14, 2008 13:46 |  #6
The least expensive Canon flash is the 220ex for around $120. (external link)
thekid17
May 14, 2008 14:27 as a reply to  @ DC Fan's post |  #7
i read a review saying the built in flash on a xt is stronger than the 220
thekid17
May 14, 2008 15:46 as a reply to  @ thekid17's post |  #8
im stuck between the sunpak 383 or the vivitar 285 hv
also when you buy a flash will it come with everything i need for it to be on the camera except batteries?
i like to shoot sports including snowboarding.
also will you tell what ill need to buy for the flahs to be off camera.
ShotByTom
Gallery: 23 photos
May 14, 2008 19:33 |  #9
THIS (external link) is about as cheap as you can get. I had a similar flash and it works well, you just put it on and it does everything for you. The problem is that it doesn't have manual, so as you learn more about flash photography, you will have to upgrade.
There are times when you won't have time to think about every shot and just want the camera to do the thinking for you, this flash will do well in those situations. If I remeber right, you can always adjust FEC in camera to add or decrease light with these flashes. Not a bad alternative for around $75. But...be very gentle with it, mine has electrical tape holding the red lens cover on the and the battery door shut from dropping it once. My Sigma has fallen off my camera twice and had no effect on it..
If I were you, I would go with the Sunpak 383 and force yourself to learn as much as you can quickly. At some point you will want to expand your capabilties and adding another 383 with wireless triggers can give you a portable 2 light setup for another $120.
Good luck!
Gear
Website (external link)
John ­ T
May 15, 2008 09:35 as a reply to  @ ShotByTom's post |  #10
The Sunpak PF30X is a good basic flash with E-TTLII.
thekid17
May 15, 2008 12:50 |  #11
a521 wrote in post #5525917 (external link)
Good luck!
hey thanks im think im gonna with the sunpak. im gonna order it when i get out school
scorpio_e
May 15, 2008 16:47 |  #12
It is really worth it to get the 430 EX. I would wait until I had enogh to but one.
www.steelcityphotograp​hy.com (external link)
supergoat
May 15, 2008 17:56 |  #13
I have a Bower SFD728C and it is TTL dedicated. Works great for most applications but now that I have practice with it I want to upgrade to a speedlight. The manual zoom on the Bower is a bit cheap feeling and annoying when you forget to match the zoom to the lens zoom. However if you set it to 50mm and toss on the nifty fifty at 2.8 you can get some fantastic, sharp shots in low light. It's a fantastic starter lens to get your feet wet with flash until you can afford one of the big boys. :)
Real world use: I have used it for two college dinner events, a graduation and will be using it for a wedding next weekend.
Canon 50D | 430exII Speedlite
Canon 50mm 1.8, Sigma 24-70 F2.8 EX HSM
1,819 views & 0 likes for this thread, 10 members have posted to it.
2625 guests, 173 members online
