PacAce wrote in post #5523891
Hmm, interesting. I never knew that. I knew that it had a bowl for video use although I never knew exactly how that worked. And I still don't.
LVL = Leveling. This is a seperate series, *not* Systematic.
Quite a bit more expensive then the comparable Mountaineer tripod, and a bit heavier.
Here's one
. If you look closely at the image, you might be able to see the center column is slightly different.
Otherwise, the Gitzo site might help out
Video Bowl: Dunno either. I think it's a "bowl" where a half ball (attached to the head) drops in. I suppose after that, either gravity takes over, or there is a kinda fastening construction at the bottom (which ISTR seeing once
Edit: Looks like it's sort of half a leveling base: The other half is attached to the video head
rjx wrote in post #5524053
I got passed the "which dslr" and "which lenses" questions on my own. But I am not sure which column I would want. The leveling base seems like it might be good for me and maybe the geared.
Is there one column most people seem to prefer? I was looking on youtube for demonstrations but didn't find anything. Any good links I should check out?
Thanks for all the replies
Geared can be nice with a heavy camera (Like a 4x5" view camera). About the only way to get a Sinar P2 a bit up or down in a controlled way
Might also have advantages for macro for instance. Not sure. Don't do much macro.
Leveling is the only way to get a leveling base into a series 2 or 3 mountaineer (not Systematic). It's also the only way to get the combination of leveling and a rapid column.
Might have an advantage, but is more expensive and heavy.
I think I'd go for a Systematic if I'd want a series 3 with leveling capability.
Then again, I level my tripod by adjusting its legs independently, so I might not be the person to ask.
One very different series, and one you might consider if you are into macro, is the Explorer series
Way different from all other Gitzo's. But a bit heavier as well, no fixed leg angles (this can be a pro or a contra), and more expensive.
