Grey card should be used to correctly set the exposure or white balance?
My first experience with grey cards was when I was taking a b&w film photo class. My impression since then has been that it's used to correctly set the balance between light and dark areas. Since 18% grey is the most common shade, setting the camera to correctly expose it will produce a correct balance between bright and dark areas. All that makes sense.
But how does it relate to White Balance?
My understanding of WB is that the temperature of light (and not exposure) will dictate the overall white balance. So how can the gray card be used to calibrate for WB?
