Thread started 14 May 2008 (Wednesday) 14:07
Ball head creep?
mismis
May 14, 2008 14:07 |  #1
I own a Bogen/manfrotto 3021 with a RRS BH-40
When I lock the focusing ball it seems to creep every so slightly, Im just wondering if small amounts of creep is normal?
For example,
When I mount a gripped XTi with a 35L on the ballhead, Loosen it and adjust the ballhead such that the center focusing point is right at a certain point, I hold the camera steady and lock the ballhead in place by turning the knob, when I let go, it shifts down ever so slightly.
Normal?
Xti + grip + RRS L-Bracket || RRS clamp + Markins M-20 + Gitzo 1345 || Kit Lens + 50mm f1.8 + 24-105L + 35L + 70-200L f2.8 IS
jhom
May 14, 2008 14:36 |  #2
Yes it is supposedly normal. I don't have the BH40, however many users report a slight but predictable movement with the BH40. I believe it has to do with the clamping mechanism used in the ballhead.
On the other hand, when I mount a similar setup as you described I do not experience any lens creep or droop with my Markins Q3. The Markins uses a different locking mechanism that doesn't exhibit the same problem.
Jim
Rey
May 14, 2008 16:43 |  #3
No creep on my RRS BH-55 but I did get noticeable creep when I was using a Manfrotto 488RC2.
Canon 5D MKII • BG-E6 • Canon EOS-M • Canon 85mm F1.2L II USM • Canon 100mm F2.8L Macro IS USM • Canon 16-35mm F2.8L II USM • Canon 24-70mm F2.8L USM • Canon 70-200mm F2.8L IS USM • Sigma 50mm F1.4 ART • Canon Speedlight 600 EX-RT • Canon Speedlite 580EX II • Canon Speedlite 430EX II • Gitzo 3530 • Really Right Stuff BH-55 LR
Tsmith
Formerly known as Bluedog_XT
May 14, 2008 21:31 |  #4
jhom wrote in post #5524066 (external link)
My Q3 is solid too and the very reason I parted ways with my Manfrotto 486CR2. I'd be extremely disappointed in a RSS head that creeped.
sml
May 14, 2008 21:54 |  #5
I've never heard of any creep on a RRS head! Or a Markins!
Give 'em a call...I'm sure they'll make it "good."
Steve L
5D Mark III, 5D Mark II, 24mm f1.4L II, 50mm f1.2L, 85mm f1.2L II, 100mm 2.8 Macro, 17-35mm f2.8 L, 24-105mm f4 L, 70-200mm f2.8 IS II L, 75-300mm f4-5.6 IS. Canon 600EX-RT, ST-E3-RT. Gitzo 2531, RRS BH-40 Ballhead.
www.stephenmlevinphoto​s.com
SnlpeR
May 15, 2008 08:54 as a reply to  @ sml's post |  #6
i just got the gadget infinity ballhead
and it moves slightly when i tighten the twoknobs
sml
May 15, 2008 09:11 |  #7
I find this quite interesting....
I've been "shopping" for a tripod and ballhead for a couple of weeks. I have pretty much nailed the ballhead to the Markins or RRS. Probably RRS at this point.
I have not used either, but I have read so many posts and articles on this (here and elsewhere) and have yet to hear of this being an issue with either. In fact, quite the contrary. That's one of the main reasons I am "upgrading!" I hope I'm doin' the right thing!!
Also, I have spoken and written to both companies and found them both to be quite responsive and proud of their products.
Steve L
mismis
May 15, 2008 09:36 as a reply to  @ sml's post |  #8
I cant speak for markins, but RRS customer service is very good.
Im not sure if its just mine because I bought the ballhead used. Im going to drop them an email today and see what they say about it.
mismis
May 15, 2008 13:56 as a reply to  @ mismis's post |  #9
"I think you will find that you notice this only when performing macro work. All ballheads will demonstrate a small amount of shift when performing the final locking step (this is actually slightly different than the “creep” you mentioned - that’s a different issue). For example, an Arca-Swiss B1 ballhead tends to shift slightly “up” and our ballheads tend to shift slightly “down.” This almost imperceptible shift occurs because of the way the tension is applied to the ball. An AS ballhead has the tensioning applied from the bottom-up, and ours is applied around the perimeter of the ball. If you’re shooting in the range of half to full-life size, then you might want to consider some sort of macro focusing rail. We do sell a few (one geared, two non-geared). It’s pretty difficult to lock down the focus without a macro rail.
Hope this helps. Let me know if you have any more questions."
Wilt
May 15, 2008 17:56 |  #10
I have read several posts from people who have stated that the Markins ball heads are free from shift as the ball is locked.
Is there anyone else who reads this thread as "Bald headed creep" like I have since this thread was started?!
argyle
May 15, 2008 18:17 |  #11
mismis wrote in post #5529263 (external link)
RRS and Markins are excellent companies to deal with,their products are top-notch, and their customer service is a cut above. I have plenty of RRS gear, but decided to go with a Markins M-10 ballhead on my new Gitzo. Markins has the best weight-to capacity ratio of any ballhead manufacturer (at the present time). With a 5D/100-400L and 5D/70-200 2.8, I don't have any creep, drift, or slip whatsoever.
René ­ Damkot
May 16, 2008 07:28 |  #12
Gave it a quick try on my M10: Put on the 80-200, tripod ring, 200mm, about closest focussing distance.
If I set the tension as loose as possible (camera almost flops over), I see a small shift upward (say: a bit more then the thickness of the line (red box) around an AF point) when locking down to max tension.
I see about the same shift if I move my eye (wearing glasses), so it's hardly noticeable.
However: In real life shooting, I set tention a bit higher, and never touch the knob again. So in testing I see a little upward shift when locking down, in real life not.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
3,746 views & 0 likes for this thread, 9 members have posted to it.
Ball head creep?
1146 guests, 176 members online
