Thread started 15 May 2008 (Thursday) 02:41
Using ETTL with wireless flash.
hsma
May 15, 2008 02:41 |  #1
I just picked up some cactus wireless triggers and after playing around with them, I was getting way over exposed pictures. The 580 was in ETTL. I know ETTL is effective when its on the hotshoe but is it still effective when its off camera? Does the ETTL still work effectively off camera?
40D + Grip, XTi + Grip, 70-200 2.8 IS, 17-55 2.8 IS, 50 1.8,
580 EX II, 430 EX
xdavex70
May 15, 2008 03:31 |  #2
The triggers are just that....a trigger. They will not enable off camera ETTL. This post explains what you need to do this...
https://photography-on-the.net/forum/showthre​ad.php?t=385912
JakeWilliams
May 15, 2008 03:32 |  #3
e-TTL can work with the speedlite flashes but from what I found out you need an e-TTL enabled transmitter. I use the canon wireless flash transmitter for this very reason and although it is a bit more costly I've been getting perfect exposure with my 430's.
Cheers
Jake
form
"inadequately equipped"
May 15, 2008 09:43 |  #4
It will fire the 580EX at full power every time if ETTL is set. Use manual.
Las Vegas Wedding Photographer: http://www.joeyallenph​oto.com (external link)
hsma
May 16, 2008 02:42 |  #5
Thanks for the clarification guys.
580 EX II, 430 EX
1,755 views & 0 likes for this thread, 4 members have posted to it.
2625 guests, 173 members online
