Thread started 15 Dec 2004 (Wednesday) 01:47
how many times can you remove the grip
xdjoynerx
Joined Jul 2004
Dec 15, 2004 01:47 |  #1
RichardtheSane
Joined Jun 2003
Dec 15, 2004 02:36 |  #2
would you mind elaborating a little more
I'm afraid I haven't a clue what you are talking about!
If in doubt, I shut up...
Gear: 40D, 12-24mm AT-X Pro, 17-85mm, Sigma 150mm Macro Sigma 100-300 F4, 550EX, other stuff that probably helps me on my way.
xdjoynerx
Joined Jul 2004
Dec 15, 2004 05:37 as a reply to  @ RichardtheSane's post |  #3
hand grip.... to take the camera apart to work on.
ron ­ chappel
Honorary Moderator
Joined Sep 2003
Dec 15, 2004 05:55 as a reply to  @ xdjoynerx's post |  #4
OK,here's what to do
First,turn off the computer and go back to the party.
Tomorrow when you can type non dyslexically please ask us the question again...if you can remember it :wink:
timmyquest
Joined Dec 2003
Dec 15, 2004 06:26 as a reply to  @ ron chappel's post |  #5
If your refering to the grip that can be bought as an accesory, it attatches in the same fashion that you attatch the camera to a tripod and can be removed as frequently as you'd like.
Capturing life a fraction of a second at a time
Red ­ Squirrel
Joined Nov 2003
Dec 15, 2004 06:28 as a reply to  @ ron chappel's post |  #6
surely everyone knows what "reguled" means? :)
See his post on FM to find out what he's on about...
http://www.fredmiranda​.com/forum/topic/16086​7 (external link)
1dmkII - 5d gripped - 24-70f2.8L 70-200f2.8L 100-400L 17-40L - 28-75di - 580exII - 85 f1.2L - 50e
PacAce
Joined Feb 2003
Dec 15, 2004 06:40 as a reply to  @ Red Squirrel's post |  #7
What language was that in 'cuz I didn't understand a single post on what was going on? ??? :D
...Leo
Belmondo
Joined Jul 2003
Dec 15, 2004 06:53 |  #8
xdjoynerx wrote:
before it needs to be reguled?
what do you guys use to re-adhere* it when its been removed too many times?
If you're talking about the battery grip, TimmyQuest has given you the correct answer. If you're talking about the plastic covering on the grip portion of your camera body, it's not supposed to be removed, so I would imagine the answer would be some kind of rubber glue or other adhesive that isn't completely permanent.
(*Hyphenated for clarity by moderator..Tom)
I'm not short. I'm concentrated awesome!
PacAce
Joined Feb 2003
Dec 15, 2004 07:16 as a reply to  @ Belmondo's post |  #9
Thanks for the clarification, Tom. Now things are starting to make sense. reguled = reglued, right? When I first saw "readhere", I kept tyring to click on it thinking it was a link to a description of the problem he was trying to get resolved. :D
...Leo
xdjoynerx
Joined Jul 2004
Dec 15, 2004 20:50 as a reply to  @ PacAce's post |  #10
H E L L O
MY NAME IS DAVID THE ROBOT.
I AM HERE TO CLARIFY THIS POST FOR Y O U.
THE HAND GRIP, WHICH IS ON THE RIGHT SIDE OF THE CANON EOS D SERIES CAMERAS. THAT YOU HOLD WITH YOUR HAND.
ok, now that grip, it is held in place by an "adhesive" or a "glue". when you remove it to make repairs, the grip looses some of its adhesion each time.
now, how many times can this be removed before you need to re glue it?
and what do you guys use to re glue it?
i mixed up the lu with ul, but the word readhere (it should have been re-adhere, but oh well, its an internet forum, not a business letter. and if you read that as read here...
) should have been enough for you guys to understand what im talking about.
ok, every one know what im talking about now???????????????///
who glues a battery grip btw
defordphoto
MKIII Aficionado
Joined Oct 2002
Dec 15, 2004 21:09 as a reply to  @ xdjoynerx's post |  #11
Yo...Calm down there. In case you hadn't noticed, Canon sells a device we sometimes refer to as BigEd, aka the BG-ED3. We also refer to it as the vertical grip, or more commonly as the grip.
I doubt you'll find 3 people here that have taken their cameras apart and I doubt anyone takes their cameras apart on anything you could refer to as a regular basis. It's just not something people do with cameras.
So, with that being said, since you disassemble your camera on a regular basis, and Canon also disassembles cameras on a regular basis, maybe even more often than you, I'd suggest calling them for advice on adhesive—maybe they will sell you some—or consider buying spare "grips" for future disassemblies.
Hope that helps.
defordphoto | Celebrating the art of photography®
SD500, 10D, 20D, 30D, 5D, 1DMKII, 1DMKIII
www.ussbaracing.com (external link) | www.rfmsports.com (external link) | www.nwfjcc.com (external link)
An austere and pleasant poetry of the real. Ansel Adams
Belmondo
Joined Jul 2003
Dec 15, 2004 21:28 as a reply to  @ xdjoynerx's post |  #12
Actually, I think we had pretty well sorted it out just before your last post. It is an unusal question. RFM is right; you should ask somebody who does this sort of thing routinely. I can't think of anyone who is brave (or crazy) enough to tackle repairing their own DSLR.
Best of luck to you.
ron ­ chappel
Honorary Moderator
Joined Sep 2003
Dec 16, 2004 04:25 as a reply to  @ xdjoynerx's post |  #13
Ok-now i got ya!
Contact glue is best i find .
Some contact glues say to apply it to both surfaces,wait for it to dry then put them together-the bond is instant.
With thin parts such as your grip-it would be easier using the wet method. Apply the glue to one part only.Assemble it while still wet so you can slide it around and so line it up exactly.
Contact glue will be similar to the bonding agent allready used on the grip-it can be peeled apart in future if you need to.Be carefull though-it will be stronger than the original glue
phili1
Joined Oct 2003
Dec 16, 2004 05:17 as a reply to  @ ron chappel's post |  #14
Well not to appear stupid but if your capable enough to repair the Camera you should know the answer and if your not whty are you taking the Camera apart?
MKII N-Canon 20D - Tamron 90MM F2.8 Macro -
Tamron 17-35 F 2.8-4 - Canon 70-200 F4 L
Canon 100-400 F4.5-5.6 IS L - Kenko Pro 300 Ext 2 X - 420 EX
Belmondo
Joined Jul 2003
Dec 16, 2004 06:07 as a reply to  @ ron chappel's post |  #15
ron chappel wrote:
Ok-now i got ya!
Did you ever try peeling the Formica off your counter tops? That's contact cement. I suspect it would be too agressive for this application.
3,023 views & 0 likes for this thread, 10 members have posted to it.
2275 guests, 136 members online
