Thread started 16 May 2008 (Friday) 12:59
Manfrotto 055XPROB center column?
snatiep
May 16, 2008 12:59 |  #1
Hello Everyone!
I'm almost ceratin I'm going to go out to my local camera shop tomorrow and pick up a Manfrotto 055XPROB tripod along with the 488RC2 ballhead.
Just two quick questions......
-What's the advantage of being able to position the center column in the tripod out at a 90' angle, parallel to the ground?
-How do you get the camera mounted on the tripod down to the listed 3.5" from the ground? You must have to remove the center column and mount the camera and ballhead to the tripod some way.
Thank You!
Nate
Jorgie
May 16, 2008 13:06 |  #2
http://www.futurelooks​.com …aluminum-tripod-review/2/ (external link)
go through the pages, its a good review of the 190 but the 055 is just a beefer version, same tripod in regards to how it works.
I have a 055xprob as well. You'll love it.
Canon XTi||Kit Lens||Tamron SP AF28-75/2.8 XR Di LD Aspherical (IF)||EF 50mm F/1.8 II ||EF 85mm f/1.8
aridan
Gallery: 15 photos
Joined Dec 2003
May 16, 2008 14:28 |  #3
1. The horizontal use is for close-to-ground tasks, or when you need to shoot straight down at a 90 degree angle.
2. You get it low, but pushing a stopper on each leg, which than opens up all three with maximum spread. You then mount the center column in a horizontal position.
5D Mark III | 135L | 24-70L | 580EXII | Flickr | Instagram (external link)
Freff
May 16, 2008 17:24 as a reply to  @ aridan's post |  #4
Borrowed from Grig at G&N....promise to put it back later.;)
Tony
"I would give my right arm to be ambidextrous"
"I used to be indecisive, but I'm not so sure anymore"
SkipD
Joined Dec 2002
May 16, 2008 17:55 |  #5
snatiep wrote in post #5537242 (external link)
Using my Bogen/Manfrotto 3021BPro (forerunner to the 055XProB), I have supported my camera on the opposite side of a wall - in other words, hanging the camera over a 500-foot cliff on the other side of a stone wall at Yosemite - to take a supported shot in a place where I would not go myself.
You can also use the feature to photograph pages from a book or something similar, with the lens aimed straight down.
Skip Douglas
Rankinia
May 17, 2008 20:36 |  #6
Curious as to why you would consider the most expensive 055 legs without knowing the benefits.
But either way its a great tripod. Though using it at its lowest settings is still a pain in the butt.
Adam
1ds, 30d, 17-40/4 180/3.5, mt-24, 580ex2
http://adamrose.wordpr​ess.com (external link)
Rehuel
May 17, 2008 21:22 as a reply to  @ Rankinia's post |  #7
Here's an example of me playing around with the tripod.
Canon 40D/BG-E2N Grip | Canon 30D/BG-E2 Grip | Canon Speedlites 580EXII, 580EX, 430EX (x2) | Canon 100-400mm L | Canon 24-70mm L | Canon 50mm | Tokina 100mm Macro
Click Here and Join the POTN flickr Group Today! (external link) www.flickr.com/photos/​rehuel (external link) www.thedmds.com (external link) http://digitalmastersd​esignstudio.blogspot.c​om (external link)
snatiep
May 18, 2008 09:27 |  #8
I'm looking at these legs because I love to walk around our lake and take pictures early in the morning or later in the evening and need to get a tripod. I have looked at the tripods at walmart and best buy, but I am the kind of person who only likes to buy things once.
Whenever a tripod question comes up here on this forum, the 055XPROB and the 488RC2 come up as a great set.
I don't know whether I should be looking at the 190XPROB, but the 055XPROB are beefier and sturdier. I think they would hold up nicely if put in a padded case and rode around in the basket on my bicycle.
What head are you using Rehuel?
Nate
Reaperman
May 18, 2008 10:22 |  #9
snatiep wrote in post #5547366 (external link)
snatiep. You won't regret the Manfrotto 055XPROB. It is an excellent choice of tripod and as you say, looked after it will last you a life-time of photography. The head I use with mine is the Manfrotto 141RC. It is a slightly older head and has the very 'dumpy' handles which I love. Makes the whole grip thing solid. These can still be purchased and is worth looking at as they can be picked up very reasonably priced.
The boom arm is excellent and has lots of uses as has been proved here with the replies you have had. I bought the genuine Manfrotto zip bag for mine and with the carrystrap it is easy to carry over a shoulder.
and Freff.... oh thank you.
Good luck with the tripod.
:lol:Reaperman
Rehuel
May 18, 2008 10:50 |  #10
The only real difference between the 190XPROB and the 055XPROB is the height (and price of course). 190XPROB is not as tall but just as sturdy and if you want to carry it around in a bike, it might be easierand it will last just as long as the 055.
The ball head on the picture is the 486 but I have since upgraded to the 488RC2. I love my new combination, the 488 is slightly bigger and has a Pan action which the 486 did not offer and of course, the quick release system which I absolutely love.
Reaperman
May 20, 2008 04:47 |  #11
Rehuel wrote in post #5547747 (external link)
Hi Rehuel.... all the reviews I have read for the two manfrotto tripods state the 190XPROB is not as sturdy as the 055XPROB. The 055 is heavier and taller. They are both excellent tripods though and I wouldn't hesitate recommending either.
Reaperman
Rehuel
May 20, 2008 12:50 |  #12
Reaperman wrote in post #5559215 (external link)
Reaperman
Technically you are correct but there isn't a colossal difference between the two in those area. The 055 is taller as it has 4 section legs instead of 3 like the 190 and this is what makes it heavier. This is also what makes the legs wider and in turn beefier. The weight difference that they can handle isn't that much and this is why I made the earlier statement. I don't view or make choices on certain things when the difference is minute. If you are a tall person, get the 055 if you are a shorter person, get the 190 and stick what ever head you want on them and be happy. This is how I see these two tripods.
10-Dee-Q
May 20, 2008 13:14 |  #13
sorry to hijack this thread,
anyway i'm looking to buy either of this tripod
the price difference is only $10 in my country between them
i'm 180 cm and using 450D which one is more suitable for me ?
tahnk you.
Canon 500D | , 50 f/1.8 MK I, 18-55 IS, 55-250 IS |
chalib_alex
May 20, 2008 23:31 |  #14
10-Dee-Q wrote in post #5561679 (external link)
tahnk you.
055 should suit your height most......
5Dmk2 + BG-E6 :lol: /50.1.8/70.200.4is/100​.2.8/24-105is/85.1.8 LX-3;)
BluewookieJim
May 21, 2008 12:43 |  #15
Rehuel wrote in post #5561538 (external link)
Are you sure about that? I use my 055XPROB very often, and I'm reasonably certain that it only has 3 section legs.
My Gear and Stuff :: My Zenfolio Gallery (external link) :: My Flickr (external link) :: http://photos.kodanja.​net (external link)
11,237 views & 0 likes for this thread, 13 members have posted to it.
2867 guests, 184 members online
