Thread started 17 May 2008 (Saturday) 09:01
What's wrong with my Speedlite 430EX?
ACF3Passion
May 17, 2008 09:01 |  #1
It worked perfectly fine for few days (I just got it).
Yesterday suddenly the ETTL zoom started not to work, meaning the display of 'Zoom 35mm' no longer shows the number and it just blinks as Zoom --mm.
Also none of the buttons respond either (C Fn, Mode, Curtain flash, Zoom). Only the pilot flash button works. Flash compensation buttons don't work either.
This morning now when I turn on flash, the unit actually beeps. Like a low 'error' buzz sound: beep beep beep. This goes away after few seconds though with the above problem persisting.
The flash still works if I shoot. But none of the control works, therefore the flash has no idea what it's doing.
The manual says blinking means to use 'wide panel', but something is clearly wrong in this case.
I use four disposable brand new Energizer batteries. I changed them all to fresh ones and problem still exists.
What's wrong?
Life is good!
XTi + Tammy 17-50mm f2.8, 85mm f1.8 & Nifty-fifty
430EX and a bobble-headed tripod that suffers from repeated verbal abuse
poloman
May 17, 2008 09:05 |  #2
Try it with a Canon lens and see if it still has the problem.
"All those who believe in psychokinesis, raise my right hand!" Steven Wright
ACF3Passion
May 17, 2008 09:09 |  #3
poloman wrote in post #5542331 (external link)
I just did with 85mm f1.8. Same thing. What's wrong?????
Life is good!
tim
Light Bringer
May 17, 2008 09:18 |  #4
Push the wide angle diffuser the whole way in.
poloman
May 17, 2008 09:23 |  #5
Turn the flash off. Take it off the camera. Turn it on. Do the buttons work now? When you reinstall it, make sure you have the unit all the way forward on the camera hot shoe.
Here is the Canon support page if all else fails...
http://www.usa.canon.c​om …id=11923#Suppor​tDetailAct (external link)
ACF3Passion
May 17, 2008 09:26 |  #6
tim wrote in post #5542378 (external link)
I don't think it has to do with diffuser. The severe symptoms I describe above (none of the buttons working) shows that something may be seriously wrong.
:sigh;
Life is good!
ACF3Passion
May 17, 2008 09:27 |  #7
poloman wrote in post #5542393 (external link)
1. I took it off the camera
2. Turned it on.
3. Now it beeps. beep beep beep. Oh man. The flash is barely a week old.
Life is good!
poloman
May 17, 2008 09:30 |  #8
Open the battery compartment and make sure the batteries are oriented correctly. If this doesn't work, call Canon. If electronic things fail, they usually fail right away.....
ACF3Passion
May 17, 2008 09:34 |  #9
poloman wrote in post #5542416 (external link)
On the phone with the support now... Thanks guys. Still provide input if the problem sounds familiar to you though.
Life is good!
tim
Light Bringer
May 17, 2008 09:41 |  #10
Flash is buggered. Get a new one.
RichSoansPhotos
May 17, 2008 12:10 |  #11
ACF3Passion wrote in post #5542404 (external link)
2. Turned it on.
best advice then is to return it
Phil ­ H
May 17, 2008 13:11 as a reply to  @ RichSoansPhotos's post |  #12
I have two 430's and they were both acting up on me yesterday in the same way described in this post. Please let us know what you find out from Canon.
EOS 7D l EF-S 10-22 l EF-S 15-85 l EF-S 17-55 l EF-S 60 Macro l EF 70-200 f/2.8L IS l EF 85 f/1.8 l 430EX x2
canonman4life
May 17, 2008 14:34 |  #13
just take it back if it doesnt work
www.scottsaxton.com (external link)
Phil ­ H
May 17, 2008 15:08 as a reply to  @ canonman4life's post |  #14
I just tried both my 430's a minute ago and they worked just fine. Yesterday when I was having the problems I was shooting outside and it was pretty hot. Any chance that heat affects the flash units?
prrs4me
May 17, 2008 15:14 |  #15
Could you possibly have put the switch to slave by mistake?
3,698 views & 0 likes for this thread, 9 members have posted to it.
2904 guests, 177 members online
