Thread started 18 May 2008 (Sunday) 10:36
EOS Utility Nightmare!!
molchew
1 post
May 18, 2008 10:36 |  #1
Hi, I have installed the canon programs on to my Laptop with XP SP2, when I start up either Picture style editor or EOS utility I get the following Message "EOS Utility has encountered a problem and needs to close. We are sorry for the inconvenience." I have also tried the latest version of EOS Utility "2.4" but get the same error. I have also loaded it on to my desktop PC which runs Vista 64 SP1 and it still will not run. My camera is a 450D.
Has anyone else had this problem? and found a solution, as I use the camera for astrophotography and would like to control it through the Laptop.
tzalman
Fatal attraction.
May 18, 2008 11:23 |  #2
You are not the only one with this problem. See:
https://photography-on-the.net/forum/showthre​ad.php?t=502374
Elie / אלי
ohansen
Nov 21, 2008 12:24 |  #3
OK so this is an old thread but I have spent a long time figuring out what was wrong, it's hard to say whether it's a Canon or Microsoft problem, but I managed to fix it an hour ago. So thought I'd post this for the record if anyone else searches for it.
If you have this problem with any of the Canon utilities (I had EOS Utility crash on me) check your XP event log, if it says something like:
Input string was not in a correct format.
at System.Number.StringTo​Number(String str, NumberStyles options,
NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal)
at System.Number.ParseInt​32(String s, NumberStyles style,
NumberFormatInfo info)
Then it's possibly because of a language setting. Go to your control panel, "Date, Time and Regional options", and "Change the format of numbers, dates and times". Choose something else like "English (United States)", apply, and check if the software works now. If so then you can set the setting back to what it was, as the registry setting will have been cleared out. For more info see:
http://www.megasolutio​ns.net …ct-format--bug-27134.aspx (external link)
http://groups.google.c​om …0425a67b/9eb8e3​00c7c60821 (external link)
7D and 60D, Sigma 12-24, Canons 24-105L, 100-400L, 50mm f1.4, 100mm Macro. 580EXII, Elinchrom Skyports, Eye-Fi, Apple Macs, iPhone 3GS, PS4, LR3. Socks and jeans with holes repaired.
wwwcjx
Nov 22, 2008 05:50 |  #4
what a funny thing.
I got this problem with Vista OS. when i see the above thread and gotta try that idea, I thought i should run the EOS Utility again to get the latest event erro log. However, at this time, guess what.... it's working properly now!!! hilarious!!!!
I recently got a new anti-virus software Norton Internet 2009 installed instead of Kaspersky. this may be the cause.
So. now you got another option.
Canon 450D, 18-55mm f3.5-5.6, EF-S 17-55mm f2.8 IS USM, 30mm f1.4, 70-200mm f4 L IS, 430EX II. Sandisk ExtremeIII 4GB;)
4,784 views & 0 likes for this thread, 4 members have posted to it.
2834 guests, 165 members online
