Thread started 20 May 2008 (Tuesday) 06:00
YN-128 remote for 40D question
Coffee999
May 20, 2008 06:00 |  #1
I just purchased this for my 40D, and I can't get the remote to work. The corded controller works great, but not the wireless controller. There is no instruction for this. With my XT you have to put the controls on timer I think, tried that with this and it didn't help.
Does anyone have this controller that can help? Thanks.
Here's the controller: http://www.alibaba.com …s_remote_contro​ls_YN.html (external link)
kristenls
May 20, 2008 20:30 |  #2
I have a similar one (sold by Adorama at $110 so I am curious as to how much yours cost ;) ).
Mine came with instructions though. First, check to see if the codes are set exactly the same on each piece - the receiver and the transmitter. Then, if that doesnt solve the problem, check the batteries. Both the receiver and transmitter have betteries (only the receiver battery comes in the package though). Perhaps the transmitter battery is dead already.
Good luck. I have only used mine a couple of times but, really like it!
Coffee999
May 21, 2008 06:02 as a reply to  @ kristenls's post |  #3
Mine was about $30.00 new on an eBay add. It was a Hong Kong supplier. I will check the batteries, but it does light up when I press the button.
Bamamike
Aug 19, 2008 17:36 as a reply to  @ Coffee999's post |  #4
Check carefully the battery for the receiver. After opening the first plastic bag, it still has a second thin clear plastic layer around it, you have to remove it prior to use. It happened to me first and I found out, that the shutter button on the receiver doesn't need power.:)
Two bodies left, some "soso" lenses, and still a lot of gear.....
CS ­ TAN
Aug 19, 2008 17:55 as a reply to  @ Bamamike's post |  #5
If all else failed, try to change all the batteries. The batteries might be too weak to trigger the device even when it can still lights up the LEDs. Saw this in another forum.
Canon 5D Mk II | EF 24-105L | EF 35L | EF 85L Mk II | EF 135L | 580EXII+430EX | Samyang 14mm
2,469 views & 0 likes for this thread, 4 members have posted to it.
2733 guests, 147 members online
