Thread started 20 May 2008 (Tuesday) 13:25
Umbrella's for Elinchrom?
irishman
May 20, 2008 13:25 |  #1
I recently purchased the Elinchrom D-4 light kit and would like to get some umbrellas. Am I stuck getting the Elinchrom version because they use a specific shaft size (7 mm, I believe?), or is there a way to use other brands? Also, if I'm shooting a group of people, maybe as many as 8-10, which size umbrella would work?
Thanks!
6D, G9, Sigma 50 1.4, Sigma 15mm Fisheye, Sigma 50 2.8 macro, Nikon 14-24G 2.8, Canon 16-35 2.8 II, Canon 24-105 f/4 IS, Canon 70-200 2.8 IS, tripod, lights, other stuff.
digitaljoe
May 20, 2008 13:38 |  #2
Photek make 7mm umbrellas (softlighter) and so does Lastolite.
I have two Photek's - useful it doubles as the normal reflective or shoot thru or you can use a diffuser cloth to provide a softlight and some of them take silver or gold reflective inserts as well. They come in various sizes - up to 60 inches.
B+H stock both brands.
DC ­ Fan
May 20, 2008 14:02 |  #3
irishman wrote in post #5561742 (external link)
Thanks!
A pair of 45-inch umbrellas should be more than enough.
slimninj4
May 20, 2008 14:59 |  #4
You will have to get the 7mm size. Phototek and Lastolite makes 7mm shaft umbrellas.
Canon 40D 5Dm3 || 24-70 L 70-200 2.8 IS2 100mm Macro 50mm 1.8 35 1.4
TMR ­ Design
Joined Feb 2006
May 20, 2008 17:54 as a reply to  @ post 5563111 |  #5
As others have stated, the only umbrellas you can use umbrellas are from Elinchrom, Photek or Lastolite due to the 7mm rod.
There is another option that works just fine. In the same way that you would mount a flash on a swivel bracket and point the flash head towards the center of the umbrella, you can do the same thing with a strobe.
If you mount an umbrella swivel bracket on a lightstand and then attach the strobe, you can attach a standard umbrella to the bracket and then point the flash towards the center of the umbrella. Give it a try before you start investing in other umbrellas or doo-dads.
Robert
irishman
May 20, 2008 22:03 |  #6
Thanks to everyone for the advice. Time was a factor because of a weekend shoot, so I went with a pair of 40"Lastolite Umbrella boxes. Hope they're alright.
TMR ­ Design
Joined Feb 2006
May 20, 2008 22:11 |  #7
irishman wrote in post #5564917 (external link)
I haven't worked with those but I've heard really nice things about them. How did you like using them? Any pros or cons to share?
Robert
bigbaby987
May 20, 2008 22:19 |  #8
i have the same kit and had/have an umbrella(photek) prior to having the kit.. i had to buy an umbrella adapter. bought the impact one from b&h and it works just fine.. something like $14. well worth it because it comes with the hotshoe post. now i can use my 580 off camera and not have to drag my kit around, especially where there's no power supplied like a park or something..
D700, D300, 28-70 2.8, 80-200 2.8, Elinchrom Dlite4 kit, CS3, and tons more inlcuding, talent, vision, determination, and blessings:D
www.BurnsideMedia.com (external link)
irishman
May 21, 2008 00:09 |  #9
TMR Design wrote in post #5564978 (external link)
Robert, just ordered them today from B&H---will be here Friday and I'll work with them Saturday and let you know.
irishman
May 21, 2008 00:13 |  #10
bigbaby987 wrote in post #5565044 (external link)
Ouch! There's always something less expensive.
bigbaby987
May 21, 2008 03:05 |  #11
irish.. no offense here, but 14 bucks will not break the bank.. you have thousands of dollars in gear in your sig. i don't know your money situation, but it's 14 dollars..
that's a steal in my book for a multi purpose adapter, or maybe i don't understand your response.
irishman
May 21, 2008 11:30 |  #12
bigbaby987 wrote in post #5566224 (external link)
My point is I just spent nearly $200 when I could havegotten by with about $50!
m3rdpwr
May 21, 2008 14:34 as a reply to  @ irishman's post |  #13
If you think the $14 is expensive, try the Bogen 2905 for ~$29.
Expensive, but well worth concidering how heavy duty it is.
Everything my teacher told me to get I was always skeptical about.
I no longer was questioning it when he turned out to be right every time I only bought one of something he said to buy two of. Or if I bought a cheaper model...
-Mario
TMR ­ Design
Joined Feb 2006
May 21, 2008 14:41 as a reply to  @ m3rdpwr's post |  #14
Hey Mario,
I use the Bogen 2905's and they are great. Until you own a better, more solid bracket you don't really appreciate that one could be better or different from another.
With the inexpensive Impact, if I used a larger, heavier modifer, I always felt like I needed to overtighten to get things stable and it felt like at some point the plastic was going to crack.
With the Bogen you can't overtighten and it's rock solid.
Robert
m3rdpwr
May 21, 2008 14:48 |  #15
TMR Design wrote in post #5569421 (external link)
Hey Mario,
I agree completely, I own 5 now and use every one usually with a minimum of 4 in use at all times!
Along with the Morris dual flash umbrella bracket with ratcheting action for super hold!
My only beef (small) with the 2905 is the small knobs for the umbrella and stud. But I guess they did that so you wouldn't crush the umbrella shaft. :)
(Did you recently start buying them, or was it a post a made a while back that you saw. I started buying them a couple years ago and love 'em!)
One othe purchase, I was only going to order 1 or 2 Bogen Superclamps as well, but he said get 4.
I was tempted to order only two, but got the 4 and glad I did.
-Mario
P.S. Still debating monolight purchases as I use all Speedlite's...
1,965 views & 0 likes for this thread, 7 members have posted to it.
2768 guests, 174 members online
