Hello, I just got a Newton bracket and love it. It's the camera rotator type (DI400CR) but kinda stiff to rotate it. Should I loosen it up or just leave it stiff. Hands start to ache after holding and rotating it. Thanks.
photo9999 Member 78 posts Joined Mar 2007 Location: San Diego CA More info | May 20, 2008 14:01 | #1 Hello, I just got a Newton bracket and love it. It's the camera rotator type (DI400CR) but kinda stiff to rotate it. Should I loosen it up or just leave it stiff. Hands start to ache after holding and rotating it. Thanks.
jrsforums Goldmember 1,249 posts Joined Feb 2005 Location: Cary (Raleigh), NC, USA More info | May 21, 2008 02:13 | #2 photo9999 wrote in post #5562025 Hello, I just got a Newton bracket and love it. It's the camera rotator type (DI400CR) but kinda stiff to rotate it. Should I loosen it up or just leave it stiff. Hands start to ache after holding and rotating it. Thanks. Over the years I have gotten comfortable adjusting mine. There IS a balance between too loose and too tight. I would start with lubricating with "3-in-1" oil (which you should do periodically) to see. Then I would call Robert Newton and have a discussion on adjusting. He can be very helpful. John
great thanks for the info. where can i get the 3 in 1 oil?
Titus213 Cream of the Crop More info | May 22, 2008 02:18 | #4 photo9999 wrote in post #5570399 great thanks for the info. where can i get the 3 in 1 oil? I would bet either you don't live in the US or you are a youngster. Dave
jrsforums Goldmember 1,249 posts Joined Feb 2005 Location: Cary (Raleigh), NC, USA More info | May 22, 2008 18:35 | #5 Titus213 wrote in post #5572772 I would bet either you don't live in the US or you are a youngster. ![]() 3-in-1 oil, while an actual product, was probably used as a catch all phrase meaning some sort of lightweight general lubricating oil. I haven't actually seen 3-in1 on the market in a long while but then I haven't been looking for it. With the advent of WD40 (I wouldn't recommend that) 3-in-1 has probably gone the way of flash cubes. And after a short search here's what I found: http://en.wikipedia.org/wiki/3-In-One_Oil Alive and kicking - I may just go buy some for nostalgic reasons. http://www.3inone.com/ John
Meaty0 Goldmember 3,519 posts Joined Jan 2006 Location: Brisbane, Australia More info | May 22, 2008 20:55 | #7 photo9999 wrote in post #5562025 Hello, I just got a Newton bracket and love it. It's the camera rotator type (DI400CR) but kinda stiff to rotate it. Should I loosen it up or just leave it stiff. Hands start to ache after holding and rotating it. Thanks. I have this model and have had a similar problem. On one outdoor shoot, I loosened the screws on the rotator and made it "excessively" sloppy. I took the Allen Key (Hex Wrench) with me and slowly tightened the bolts a little at a time until I found the right balance between stiffness and usability. After that I just simply oiled the hinges with sewing machine oil.
May 23, 2008 14:24 | #8 Thanks everyone for the help, greatly appreciated.
| Latest registered member is josetide 1048 guests, 171 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
