I'm kind of confused with this one. Initially, should i just shoot the white piece of paper with Auto WB? or should I set it to the preset WB of my ambiet light? Am I supposed to use a flash to take a picture of the white piece of paper?
thanks!
markubig Goldmember 1,953 posts Likes: 1 Joined Nov 2004 Location: NJ USA More info | Dec 18, 2004 00:37 | #1 I'm kind of confused with this one. Initially, should i just shoot the white piece of paper with Auto WB? or should I set it to the preset WB of my ambiet light? Am I supposed to use a flash to take a picture of the white piece of paper? ~Mark
FlyingPete I am immune More info | Dec 18, 2004 01:36 | #2 Take the shot of the white paper with the light you will taking the pictures under, don't be too fussed about the white balance setting that the camera is set too when you shoot, the camera will take that into account. Peter Lowden.
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Dec 18, 2004 01:36 | #3 I mainly use auto white ballance and correct it later in photoshop. If you don't want to have to do that yes, use a custom white ballance. Shoot a white piece of paper, and make sure the centre around your AF points are all white. *Do not* use the flash, as it emits a white colored light. Go into the menu, find custom white ballance, and chose your paper shot. Then hit the WB key (down arrow) and scroll until you get to custom white ballance (the bottom right one on my 300D). Then shoot away, in any mode you like Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
robertwgross Cream of the Crop 9,462 posts Likes: 3 Joined Nov 2002 Location: California More info | Dec 18, 2004 01:42 | #4 Page 52 in your manual explains it pretty well.
FlyingPete I am immune More info | tim wrote: I mainly use auto white ballance and correct it later in photoshop. If you don't want to have to do that yes, use a custom white ballance. Shoot a white piece of paper, and make sure the centre around your AF points are all white. *Do not* use the flash, as it emits a white colored light. Go into the menu, find custom white ballance, and chose your paper shot. Then hit the WB key (down arrow) and scroll until you get to custom white ballance (the bottom right one on my 300D). Then shoot away, in any mode you like ![]() Hey Tim, Peter Lowden.
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | FlyingPete wrote: Hey Tim, Have you managed to correct an image that the WB is grossly wrong in? i.e. having the WB on tungsten when shooting outdoors. This has happened a couple of times on the G3 by accident a couple of times usually with someone who is not familar with the camera. I've never shot one that bad. If you want me to give it a go email it over to me. I'll PM you my email. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
Dec 18, 2004 08:22 | #7 OOOOOHHHHHHHH THAT'S WHY . . . . ~Mark
robertwgross Cream of the Crop 9,462 posts Likes: 3 Joined Nov 2002 Location: California More info | If you shoot with mixed tungsten light and flash, then you're likely to have color balance problems, because the camera has to guess whether the white is the tungsten white or the flash white. Whenever possible, have one source of light be predominant in the scene, and let the camera white selection be that one.
PhotosGuy Cream of the Crop, R.I.P. More info | Dec 18, 2004 13:11 | #9 Make sure that the pic you take has some tone in it - looks gray instead of white. About 1 stop underexposed should do it. The cam needs pixels that aren't blown out to make the calculations. FrankC - 20D, RAW, Manual everything...
Now once I take the white paper pic and set the custom WB to that, do I need to keep that pic on the CF card, or can i delete it to conserve space. I have a 2GB card, so I doubt I need to worry about space, but just in case the situation comes up? ~Mark
robertwgross Cream of the Crop 9,462 posts Likes: 3 Joined Nov 2002 Location: California More info | Once you set a Custom White Balance (based on some image on the card), then all that the camera has to actually save is the white color temperature value that you say is Custom. So, it saves a number off to memory, just like other settings that it remembers, completely separate from images on the CF card.
thank you all for your help on this subject!!! ~Mark
| Latest registered member was a spammer, and banned as such! 2275 guests, 136 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
