I have noticed that i have some issues with some of my photo's
I am seeing some softness in some of my photo's I am not sure why that is.. any advise on how to make the pictures sharper.
ItzBitzHair Senior Member 405 posts Joined Feb 2008 Location: Ga/SC Boarder More info | May 20, 2008 22:18 | #1 I have noticed that i have some issues with some of my photo's www.haasports.info
PaulS Senior Member 585 posts Likes: 3 Joined Jan 2008 Location: New England More info | May 20, 2008 22:20 | #2 |
Aaagogo Goldmember 2,403 posts Likes: 1 Joined Oct 2006 Location: Daytona Beach, FL More info | May 20, 2008 22:22 | #3 i'm assuming that the center is sharp but the face is a little soft? https://photography-on-the.net …p?p=4655753&postcount=953 Your 1st 10,000 images are your worst
May 20, 2008 22:37 | #4
www.haasports.info
May 20, 2008 22:41 | #5 More Example
www.haasports.info
BrownDogWilson Goldmember 1,456 posts Likes: 286 Joined Aug 2006 More info | You need more light for sure... 1DX, 1D MarkIV, 5D MarkIII, 70-200mm 2.8., 400mm 2.8, 24-70 2.8, 17-40, 15mm
May 20, 2008 23:06 | #7 Aaagogo wrote in post #5565064 i'm assuming that the center is sharp but the face is a little soft? I seem to have this issue with soccer photos. Is it something I am doing (I assume it would be) 5D Mk IV | 24-105L | 85 1.8 | 70-200L 2.8 IS MkII | 100-400L MkII
dmwierz Goldmember 2,376 posts Likes: 2 Joined May 2005 Location: Chicago Area, IL More info | May 21, 2008 00:43 | #8 If you want help, you're gonna need to either not strip the EXIF data from your images (which you did - most likely by doing a "Save for Web" in Photoshop) or post the EXIF info along with each shot. You'll also need to tell us what AF scheme you were using and which exposure mode you were in. http://www.denniswierzbicki.com
May 21, 2008 08:38 | #9 ok i saved the photo's in dpp sorry I was not aware it was gone. www.haasports.info
May 21, 2008 08:41 | #10 pic one and three was also the same as above also. They have a softness as you can see they do not look really crips so that something pop's out.... in sharp focus. please give any help as it is alwasy appreciates. I am trying to get better www.haasports.info
namasste Cream of the Crop 6,911 posts Likes: 140 Joined Jul 2007 Location: NE Ohio More info | ITz, the exif on #2 might make that gym win the prize for worst lighting ever. 1/200-3200-f2.8 and that dark? The ONLY thing that's going to help there is some flash. You'll get effective shutter speeds much higher than you can shooting ambient in there and your colors should have a bit more zest to them. Shooting wide open with that slow shutter is definitely one of the reasons for being soft. Another can simply be a little shake while shooting. IT doesn't take much movement on a zoom to induce soft or even very blurry images. Scott Evans Photography
May 21, 2008 08:55 | #12 ok I have my clamps finally but i have 2 430's i will have to buy a transmitter so they will work. www.haasports.info
bobbyz Cream of the Crop 20,506 posts Likes: 3479 Joined Nov 2007 Location: Bay Area, CA More info | May 21, 2008 09:20 | #13 I think you need to use th right tool for the job. I still don't get why don't you try your 85mm f1.8 for these shots. Sorry to be harsh but every time people suggest that you don't strip exif, you do. Most important things are, Fuji XT-1, 18-55mm
May 21, 2008 09:32 | #14 I do sometimes use the 85mm this gym the ways its built behing the goal is right at the goal. I am soo close i cant even get a shot unless its away from the goal at this particular location. i did some shots with is but didn't get anything but an arm or leg in the photos cause i was sooo close. its not that I dont listen. I do listen to every work said to me or written :0) sometimes i can use it and sometimes i just tooooo close is all. And secondly.. I NEVER I MEAN NEVER Ever has stripped info. never. I dont know how its stripped. www.haasports.info
namasste Cream of the Crop 6,911 posts Likes: 140 Joined Jul 2007 Location: NE Ohio More info | May 21, 2008 09:32 | #15 bobbyz wrote in post #5567476 I don't think 24-70mm f2.8 is a fast focussing lens. Could be wrong as I haven't used it. agreed on all points Bobby. LEAVE THE EXIF INTACT!!! Scott Evans Photography
| Latest registered member was a spammer, and banned as such! 2794 guests, 156 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
