Thread started 22 May 2008 (Thursday) 22:43
Before & After 61
ZeroOne86
May 22, 2008 22:43 |  #1
This game is to help those of us who are trying to learn new tricks when it comes to editing.
Here's the breakdown of the game. I will post a picture that I choose, resized to exactly 800 pixels maximum on the long side. Outside of being resized it has to be unedited...meaning no adjustments to any levels, it has to look like it did as it came out of the camera.
The game will last 48hrs and whoever can produce the best edited image (as judged by me) will be picked and it'll be their turn to post their unedited picture for all of us to take a crack at.
If you happen to be the winner of the game please start the next one with the title of the game and the following number. For example…the next game should read (Before and After #62).
This is all about having fun so have at it!!!
This will end on Saturday, May 24th at 11pm (EST).
This one I took on the flightline at work a while back will be interesting to see what y'all come up with. Good luck :D
Canon Rebel XTi 18-55mm, 50mm f1.8, 430 EX
Foxgguy2001
May 23, 2008 02:44 |  #2
A quick go at it... i'm fairly new to photoshop, been using fireworks forever... just tried to allow focus simply on the plane itself... Hope it's at least decent :confused:
  • cloned out red flags and other destracting items.
  • Created bracketed exposures in PS.
  • Processed in photomatix.
  • Framed
My humble beginnings: Canon XTI, 17-85 IS, 50mm 1.8
BitterSweet
May 23, 2008 03:35 |  #3
-Cloned out straps, red flags, and line on ground.
-low key filter to lower the blown out sky (no clouds that day at all really lol)
-tonal contrast filter to bring out the details in the jet and ground.
-sunshine filter. Two layer and different opacities one for the jet and ground and then one for just the jet.
-Cropped
-Darken/Lighten center filter because a vignette just didn't seem to work out well.
-Added border and text.
Tracey McCloskey
www.Bitter-Sweet-Photography.com (external link)
Model Mayhem Link http://www.modelmayhem​.com/bittersweetphotog​raphy (external link)
Mark0159
I say stupid things all the time
Gallery: 45 photos
Joined Mar 2003
May 23, 2008 05:06 |  #4
OK, Here is my attempt :)
  • created a mask to remove the sky from the plane and the rest of the background
  • found a nice sunset photo to full in the sky
  • create a mask of the buildings and fulled in the area black. change the layer to multiply and change the opacity level of that layer down to 69%
  • created a bigger shadow to go under the plane and applied a Gaussian blur to it.
  • copied the layer of the plane and applied some burn tool to the areas I wanted to make darker.
  • made another copy of the plane and change it to an overlay
  • applied some dodge tool to this layer to brighten some areas I thought needed to be brightened
  • added some colour of the sky to the top of the plane to match some of the light coming from the sunset.
  • adjusted the sky layer with level adjustment to make the sky darker so it seem that the sun is setting more than it really is.
  • flattened the image and applied a small amount of USM
Mark
https://www.flickr.com​/photos/52782633@N04 (external link)
Canon EOS 6D | Canon EF 24-105mm f/4L IS USM, EF 17-40mm f/4L USM, EF 50mm f/1.4 USM, EF 100mm f/2.8 Macro USM | Tamron SP 35mm F1.8 Di VC USD | Canon Speedlite 550EX -|- Film | Canon EOS 3 | Olympus OM2 | Zuiko 35mm f2
PeteJaffa
man eating virus
May 23, 2008 10:41 |  #5
The End
Can I include this one just for fun?
Currently Reading: A Song of Ice and Fire - Game Of Thrones
Foxgguy2001
May 23, 2008 11:27 as a reply to  @ PeteJaffa's post |  #6
I actually really dig the magenta/purple sky, and hard shadows. Looks cool.
+1 for the descent spacecraft strafing over the jet... been a long time since I've played descent.
thekid24
pro-zack-lee
May 23, 2008 13:23 |  #7
---had to create vignette using create a layer, filled with white, selected screen blend mode, marquee tool, feathered, inversed, adjusted brightness and contrast, then
merge visible layers
---adjusted curves...made the 'S' shape
---adjusted colors using levels
---switched to LAB colors
---selected 'lightness' under channels
---unsharp mask 50,50,0
---switched back to RGB
---created another layer
---filled with 50% gray
edit: OH YEAH....cropped:)
---set layer to overlay
---added film grain under 'artistic'
---slightly gaussian blurred layer
---merged visible
DONE
Permagrin
May 23, 2008 13:34 as a reply to  @ thekid24's post |  #8
first added clouds and flattened.
then made 6 total exposures at 2/3 and blended in photomatix.
then added a tonal contrast filter
then added an additional layer of infrared b&w and turned it to multiply (to grunge things up a bit) and opacity 70%
then used a darken edges lighten center filter and flattened and saved
suzyb
May 23, 2008 14:49 |  #9
Sunrise? Sunset?
First I did the usual...levels, contrast, shadows, etc.
Then I added filters in yellow, orange and red.
Added filter-render-lighting effect-omni to make the bright spot behind the plane.
Some noise reduction/sharpening.
Cropped a little bit off the sky.
Added the border...which now I'm not liking too much, but oh well.
IMAGE: http://farm4.static.flickr.com/3015/2517046308_0a57b61ecb_o.jpg
Ocron
May 23, 2008 15:13 as a reply to  @ suzyb's post |  #10
This was a fun picture to play with. Here's what I did...
- Graduated filter @70 opacity
- Added the sky using screen blend mode
- Added a 2nd sky layer using normal blend mode @15% opacity
- Added a 3rd sky and masked off everything but the birds (they were too transparent before doing this)
- Bleach bypass everything but the sky at 80% opacity
- Bleach bypass the sky at 50% opacity
- LAB soft light apply image, Color blend mode
- Brightened the bottom of the plane a bit
- light vignette and border
Sean
AngryCorgi
-Bouncing Boy- a POTN peion
Location: Surrounded by bunnies, squirrels and a couple of crazy corgis in NoVA...
May 23, 2008 23:49 |  #11
Ok...I had a vision of this machine having served it's purpose, now many years down the road it sits in a desert graveyard (like in an abandoned airfield)...
*Started with 3 layers (aircraft, ground, background)
*Tossed the background and gave it a mountain-desertesque backdrop
*Used ocean ripple judiciously with a feather to simulate heat-induced ripples near the ground/aircraft
*Painted in some war beauty marks and placed prominent rust marks, stronger near larger joints
*Placed severe rip/gnash marks on the tail
*Dirtied up the glass and made it look abused
*Lensflare originating where the sun was actually setting in the backdrop image
*Roughed up the mountain silhoutte some to lessen its distracting sharpness
And there we are...
AngryCorgi (external link) (aka Tom) ...Tools...
...Knowledge is knowing that a tomato is a fruit, Wisdom is knowing not to include it in a fruit salad...
ZeroOne86
May 24, 2008 22:52 |  #12
Hey y'all sorry for the hour overlay had to assist the wife on a photo shoot today. I'm picking AngryCorgi as the winner. I think the image looks very cool would have been interesting to see if you added the white coating to the canopy that protects the avionics in the cockpit. The coating that they put on jets that go to Davis-Monthan AFB boneyard. Everyone else great edits and Permagrin I really like how yours turned out it looks like the drawing that we have on our plaques that we hand out for people PCS'ing. Congrats again to AngryCorgi.
AngryCorgi
May 24, 2008 23:08 as a reply to  @ ZeroOne86's post |  #13
Thanks Zero! You know, I had just watched a special on TV on the B-17, and was inspired by seeing all those great WW2 planes waiting to get the axe. I was mildly tempted to place markers on the side to represent combat kills, but I was not sure if that even occurs anymore. I'll have to research the protective covering so I'll be better educated for future PSing. ;)
Everybody's edits looked great, so I feel all the more honored.
Permagrin
May 25, 2008 00:00 as a reply to  @ AngryCorgi's post |  #14
congratulations Corgi.
Thanks Zero (I think...I don't know what PSCing is :lol:)
Kiwi, LOVED Your edit...making it a sunset shot (and such a seamless edit too) was a great touch ;)
Mark0159
Gallery: 45 photos
Joined Mar 2003
May 25, 2008 00:19 |  #15
congrats to AngryCorgi, I nice edit.
Thanks Permagrin, your a sweet girl, esp now that your out of the corner ;)
I will look forward to the next photo.
Mark
3,047 views & 0 likes for this thread, 10 members have posted to it.
Before & After 61
1605 guests, 140 members online
