Thread started 23 May 2008 (Friday) 00:00
Autofocus points and landscape...
troyer16
May 23, 2008 00:00 |  #1
Lets say you wanted to take a landscape shot with everything in focus. Would you use your center autofocus point and focus on something far away, or use all of the autofocus points? Thanks for any help.
Canon Digital Rebel XT (350D)
Canon Rebel X (Film)
Canon EF 17-40 f/4 L
Tamron EFS 70-300mm/Macro
www.adamtroyerphotogra​phy.com (external link)
Anke
May 23, 2008 00:36 |  #2
You should focus a third of the way into the image, I tried to find a photo to explain and rather handily found a whole article:
http://digital-photography-school.com …in-landscape-photography/ (external link)
Anke
Stocky
May 23, 2008 01:54 |  #3
How about None of the AF points?
What I think you want to know is:
To get the most possible area in focus use the hyperfocal distance.
http://www.dofmaster.c​om/hyperfocal.html (external link)
The DOF calculator on the side will even calculate it for any camera, lens, aperture combination you may have.
Always happy to hear some critique
gear list
argyle
May 23, 2008 06:58 |  #4
Stocky wrote in post #5579896 (external link)
Need to be careful when using DOF scales and tables. The circle of confusion factor (CoC) is dependent upon the size of the expected final print. Typically, the "standard" CoC is based on an 8x10 print, IIRC. You can compensate by either factoring in a specific CoC value for a larger print, or by adjusting the aperture...just something to be aware of.
Stocky
May 23, 2008 07:44 |  #5
Do you know how the final print size effects the CoC size? Would the DOF be significantly shorter on a 20x30 print?
gear list
troyer16
May 23, 2008 09:31 |  #6
No, i simply want to know which AF point you use.
chauncey
May 23, 2008 09:59 as a reply to  @ troyer16's post |  #7
I use nothing but center focus point.
Pick your focus point, then lock it by holding your shutter half way down and recompose and depress shutter the rest of the way as described in Anke's link.
Stocky
May 23, 2008 10:56 |  #8
sorry if I mistook you for someone who wanted to know what to do and why in order to get the best picture out of the camera. If you don't want to know where you should actually focus then I recommend using all of the focus points and letting the camera pick one for you. In this case IT is likely to make the better choice anyway.
gear list
kevin_c
May 23, 2008 11:18 |  #9
I tend to use the centre focus point, lock focus and then switch to MF. This way i can recompose and not worry about accidentally firing off the shutter or letting go and missing the focus.
-- K e v i n --
Nikon D700, 17-35mm, 28-105mm, 70-200mmVR, 50mm f/1.4
Canon EOS 3, 24-105L, 135L
troyer16
May 23, 2008 11:27 |  #10
Stocky wrote in post #5582049 (external link)
thanks, but with responses like that, you can keep your help to yourself.
Cody21
May 23, 2008 12:26 |  #11
kevin_c wrote in post #5582162 (external link)
Kevin .. curious why you wouldn't just use MF instead of the whole "center focus, lock...." What benefit is there to your process? or is that a misprint? Did you mean M and not MF ?
5DM3 | 16-35mm f/2.8L II USM | 70-200mm IS f/4L | 24-105 f/4L | Sigma 18-50mm f2.8 | Speedlite 430EX
chauncey
May 23, 2008 12:29 as a reply to  @ troyer16's post |  #12
A 2 year member and you don't know that everything cannot be in focus?
Even a flat wall will have lens distortion and the edges won't be in focus.
kevin_c
May 23, 2008 13:04 |  #13
Cody21 wrote in post #5582594 (external link)
I just find it easier to use AF to 'zap' the selected focus point/area, besides my ageing eyes aren't as good as they used to be :) - DSLR focus screens aren't that good for MF in my experience. On my old MF film cameras it's much easier to focus manually with a split prism focus screen...
-- K e v i n --
troyer16
May 23, 2008 22:12 |  #14
chauncey wrote in post #5582620 (external link)
wow i thought this was the place for help, not getting attacked. I guess this forum isnt as 'friendly' as everyone makes it out to be.
Anke
May 23, 2008 22:17 |  #15
troyer16 wrote in post #5585804 (external link)
Hmm that was rather harsh wasn't it. That's not the sort of advice that POTN is all about. You can report the post to a mod by clicking the /!\ button if you want.
Anke
2,244 views & 0 likes for this thread, 11 members have posted to it.
2657 guests, 155 members online
