Thread started 23 May 2008 (Friday) 02:13
testing 40d body
av3nger
May 23, 2008 02:13 |  #1
hi. i've just recieved a new 40d. how do i test it? i've heard that you need to take a picture with a cap on and check for something... can someone please tell me more about this?
nordstern1
May 23, 2008 02:54 |  #2
how bout...just use it? take pictures?:confused:
by the way, congrats on your new camera!:D
JOE
G10 | 5D | 40D | 17-55 2.8 IS | 16-35 2.8 L II | 24-70 2.8 L | 70-200 2.8 IS L | 85 1.2 L II | 430EX
manfrotto | tenba | crumpler | clik elite | tamrac | op/tech | blackrapid | sandisk | b+w | marumi | giottos | mac | buffalo
av3nger
May 23, 2008 02:58 |  #3
thanks ))
why wait. what if there's a problem. i can exchange it now. in a couple of weeks i'll have to take it to service, because i won't be able to excange it anymore.
FlexiPack
May 23, 2008 03:24 |  #4
I'm not aware of any test with the cap on but I 100% agree with Jo, go out and use it and have fun! If there are any probs you'll soon become aware of them
Body: 450D
Lenses: Sigma EX 18-50mm 2.8 Macro; EF 50mm f/1.8 MKII; EF 100mm Macro f/2.8; EF 70-300mm IS; Zeiss S 135mm f/3.5;
Accesories: 430EX; Vivitar 285; Kenko DG Extension Tubes;
evandavies
Joined Feb 2006
May 23, 2008 03:38 |  #5
The "test" with cap on is to reduce sensor noise.
1. Leave cap ON lens
2. Activate MANUAL cleaning mode
3. When mirror flicks up wait about a minute.
4. Turn camera OFF then use as normal. (you can then turn on and take pics)
Its reputed to reduce sensor noise but its not necessary.
Best way to test your camera is to take lots of pics. If you have any questions or anything looks strange then do a search here to see if there is a topic on the matter.
E:¬D
- Gallery - (external link)
= Gear =
Lens focuses the light,
camera records the light,
you make it art.
lkb-28
May 23, 2008 03:39 |  #6
av3ngr;
Unless you acquired the camera from a "dodgy-dealer" you have at least a one-year manufacturers warrenty on the unit...
Don't worry about it. Use it with a selection of lenses, and with a few different function settings - that's the very best way of determining whether or not there are any problems...
As far as the "cap" test goes, I "think" that all you will see is any blown pixels. Not a factor, because they can be programmed out if there is a real problem...
Cheers;
Lee
Comments & Criticisms ALWAYS welcome...:D
Still a rank amateur - but learning day by day...:D
Equipment
Tsmith
Formerly known as Bluedog_XT
May 23, 2008 07:27 |  #7
lkb-28 wrote in post #5580138 (external link)
av3ngr;
Cheers;
Lee
Well said
Tiberius
May 23, 2008 07:50 |  #8
The noise reduction is operated by a custom function. It happens automatically if the custom function is activated. When you take a long exposure photo, the camera takes a second photo without opening the shutter to get a photo that is just noise. It then uses this to reduce the noise in the actual photo. This can slow down your photography, as if you take a 30 second photo, the camera must take a thirty second exposure for noise reduction.
My photography website!PHOCAL PHOTOGRAPHY (external link)
gjl711
May 23, 2008 08:35 |  #9
Your talking about a dark frame test used to check for noise. Just take a pic with the body cap on and look at the image. Some noise is normal and depending on the length of exposure and ISO the noise can vary. If a pixel is hot, you’ll see one like a beacon shining away. If you get one, maybe two like this, do the mapping fix listed above. If there are a bunch, you might consider swapping bodies.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
Stormin_24
May 23, 2008 08:55 |  #10
Congrats on your new toy and welcome to POTN...
Get out there and shoot... You'll know soon enough if there's a problem or not...
New Hampshire State Bird: Purple Finch
http://www.netstate.co​m …birds/nh_purple​_finch.htm (external link)
Gear
Norman
Did they get you to trade, your hero's for ghosts?
LucisPictor
May 23, 2008 09:03 |  #11
Not noise, but hot pixels can be shown this way...
My tools? 5D & 40D with many lenses...
1,202 views & 0 likes for this thread, 10 members have posted to it.
testing 40d body
2467 guests, 100 members online
