[SOLVED!]
Hello everyone,
I was hoping my first post would be more of a contribution than this, but after reading so many interesting posts on this forum I figured this might be one of the best places to ask.
I just received a used OC-E3 ETTL off-camera cable (the official Canon 60cm one), and did some test shots when I realized that the flash was firing at full strength every time! Pondered, I tried over and over again, and when I turned the flash towards me I could feel how warm the light from the flash was every time I pressed down the shutter. All shots come out completely white, and I stopped messing with it quite fast because I thought it couldn't be a good thing to have the flash fire at full strength over and over again (not to mention my vision still hasn't returned to normal).
Still connected via the cable, I tried setting the flash manually, and it behaved according to the settings I made. After putting the flash directly back on the body again to see that the ETTL actually works on the body to begin with (I've used it several times before, but checked to make sure), I'm thinking maybe I've been sold a damaged cable, or that it got damaged on the way.
Any ideas? Do I need to set up anything in particular, or be in a particular mode on the camera for it to work properly with the off-camera TTL-cord?
My body is a Canon 30D.
Flash: 580 EX II
Cable: OC-E3
