Thread started 24 May 2008 (Saturday) 21:41
What happened?
DerekRob
May 24, 2008 21:41 |  #1
IMAGE: http://i3.photobucket.com/albums/y98/Docpeplvr/steelguitar/ed900ea3.jpg
Tv mod
iso 100
Shutter speed 1/2000
uv filter + macro
Is it because the iso was 100 when we didn't need such a low iso? The sun was full on when you can by the photo.
And this is me by the way
eddarr
There's Moderators under there....
May 24, 2008 22:29 |  #2
Looks like it was in manual focus and not focused on the subject. The dobro is reasonable clear around your knees.
Eric
DerekRob
May 24, 2008 22:31 |  #3
eddarr wrote in post #5590626 (external link)
Is it because of the macro filter?
and I've used the auto focus feature.
eddarr
May 24, 2008 22:41 |  #4
You had an add on macro filter on front of the lens? That would definitely be it. It was trying to focus about a foot in front of the lens.
Eric
DerekRob
May 24, 2008 22:46 |  #5
eddarr wrote in post #5590689 (external link)
I did, So the iso was ok though?
gdykstra
May 24, 2008 22:53 |  #6
Here is your Exif data, your shutter speed was 1/200 not 1/2000. But that should not have made a difference for this shot. Why would you use a macro filter?
Exif IFD0
* Camera Make = Canon
* Camera Model = Canon EOS DIGITAL REBEL XTi
* Picture Orientation = normal (1)
* X-Resolution = 72/1 = 72
* Y-Resolution = 72/1 = 72
* X/Y-Resolution Unit = inch (2)
* Last Modified Date/Time = 2008:05:24 06:14:52
* White Point Chromaticity = 313/1000,329/1000 = 0.313, 0.329,
* Primary Chromaticities = 64/100,33/100,21/100,7​1/100,15/100,6/100 = 0.64, 0.33, 0.21, 0.71, 0.15, 0.06,
* Y/Cb/Cr Coefficients = 299/1000,587/1000,114/​1000 = 0.299, 0.587, 0.114,
* Y/Cb/Cr Positioning (Subsampling) = co-sited / datum point (2)
Exif Sub IFD
* Exposure Time (1 / Shutter Speed) = 1/200 second = 0.005 second
* Lens F-Number/F-Stop = 67/10 = F6.7
* Exposure Program = shutter priority (4)
* ISO Speed Ratings = 100
* Exif Version = 0221
* Original Date/Time = 2008:05:24 06:14:52
* Digitization Date/Time = 2008:05:24 06:14:52
* Components Configuration = 0x01,0x02,0x03,0x00 / YCbCr
* Shutter Speed Value (APEX) = 500948/65536
Shutter Speed (Exposure Time) = 1/200 second
* Aperture Value (APEX) = 359683/65536
Aperture = F6.7
* Exposure Bias (EV) = 0/2 = 0
* Metering Mode = average (1)
* Flash = Flash fired, compulsory flash mode
* Focal Length = 55/1 mm = 55 mm
* FlashPix Version = 0100
* Colour Space = 65535
* Image Width = 3888 pixels
* Image Height = 2592 pixels
* Focal Plane X-Resolution = 3888000/877 = 4433.3
* Focal Plane Y-Resolution = 2592000/582 = 4453.61
* Focal Plane X/Y-Resolution Unit = inch (2)
* Custom Rendered = normal process (0)
* Exposure Mode = auto exposure (0)
* White Balance = auto (0)
* Scene Capture Type = standard (0)
* Unknown tag: Tagnum = 0xa500 ===> data = 22/10
Model Mayhem (external link) | Website (external link) 5D Mark III|5D Mark II|TSE 17mm f/4.0 L|24-70L f/2.8|85L f/1.2 II|135L f/2.0|70-200mm f/2.8L IS II|400mm f/5.6L|100mm f/2.8 Macro|15mm f/2.8
eddarr
May 24, 2008 22:53 |  #7
You want to use as low an ISO as possible to get a good shutter speed. So yes.
Eric
DerekRob
May 24, 2008 22:56 |  #8
Ok and I've read on this forum it was a good idea to use a macro filter when you shoot in tv mode and or portret mode.
eddarr
May 24, 2008 23:07 |  #9
Boy would I like to see who said that. I think you may have had a brain fart. No filter is best used when shooting in tv or portrait mode. The camera mode has nothing to do with filters or lens. And definitely not a macro filter. They are about the worst thing you could put in front of a lens.
Eric
jra
May 24, 2008 23:08 |  #10
I would agree....drop the macro filter.
DerekRob
May 24, 2008 23:11 |  #11
So drop the macro filter and the uv filter? or keep the uv filter?
I have a shoot tomorrow and I really need a crutch for shooting indoors in a medium size room with ok lighting.
eddarr
May 24, 2008 23:17 |  #12
If it is a quality UV filter you can leave it on. It will do a decent job of protecting the lens.
Shoot in manual if you are used to it. Otherwise, shoot in AV at around f/6.0 with as low an ISO that will keep the shutter speed above 1/125 or so. If the shutter speed is to slow then increase the ISO.
Eric
DerekRob
May 24, 2008 23:21 |  #13
eddarr wrote in post #5590835 (external link)
I can do and I'm not used to m mode yet.
DerekRob
May 25, 2008 00:30 |  #14
I'm surprised you knew what a do-bro was, Thats cool.
Glenn ­ NK
May 25, 2008 01:15 |  #15
The most common and descriptive name for a "macro filter" is "closeup lens". I have a Canon 500D (pricy as hell), and it really limits the maximum focus distance of any lens. On my 24/105 at a FL of 105 mm, the maximum focus distance is about three feet; at 24 mm, it's about eight feet. Obviously neither are anywhere near infinity.
Regarding the UV filter; if it's high quality, then it will seldom cause problems (seldom, not never). The B+W filters are high quality (as are another German brand - Rodenstock - I have two of each).
I also hope you are using the lens hood - always. A little bit of light on a UV filter (particularly a cheap one), or light on the lens, and you'll encounter lens flare.
When did voluptuous become voluminous?
1,730 views & 0 likes for this thread, 7 members have posted to it.
What happened?
2863 guests, 169 members online
