alright guys so i've been doing some research on flash techniques and how to properly expose.. and i was reading here and i don't understand what this underexpose 2 stops means. i don't even know what the "2 stops" means. is that the f stop, or the exposure meter? here's the entry from where i was reading...
quoted from strobist.blogspot.com . .
"Bearing in mind your original ambient exposure was a 60th at f/4, you want to drop the ambient down, say, two stops. This will create your shadows - but with detail. Assuming your camera can synch at up to a 250th of a sec, you have several choices. You can stay at a 60th and go to f/8, for depth, but your flash will have to work a little harder to put out the extra light to support that aperture.
You can keep the aperture at f/4 and go to a 250th of a sec., which might be a good choice if you are powering with AA's and/or want faster recycle times for better chance at grabbing moments.
You could split the difference and go to 125th at f/5.6. Whatever. The idea is to build an ambient-light-only exposure that would result in an underexposure of 2 stops. That will be your lighting ratio. You can choose another ratio (and you should experiment) but 2 stops is a good starting point."
i don't understand how flash is in conjunction with the fstop, but i understand how it is with the shutter speed.
can someone help explain this to me? i really want to learn and have been reading nonstop about a lot of things, and maybe it's just that i'm cramming too much in at one time...
help?
