Thread started 25 May 2008 (Sunday) 21:29
Vivitar Thyristor 285
sacral
May 25, 2008 21:29 |  #1
Hey all
My father just gave me his old Vivitar thyristor 285 speedlight. Does anyone have any experience with this? Is it safe to use on a 30D? I'm pretty sure it's not TTL, but i feel like i could save money from buying a 430EX or 580EX...
any thoughts?
Thanks!
5D classic | 5DmkII | Lenses | Flashes | Blood/sweat/tears
Positive Feedback: #1 |#2 |#3
Rudi
Joined Mar 2002
May 26, 2008 03:20 |  #2
AFAIK, the 285's trigger voltage can be too high for the 30D. Some of those old flashes, when measured, show voltages over 300V! I'd check it with a multimeter before using it in your 30D's hot shoe. If you want to use it off-camera, through your camera's PC sync, check your Owner's Manual (not sure of the 30D tolerates higher voltages, most of the new Canons do tolerate up to 250V through the PC sync though).
• Wedding Photographer - Sydney and Wollongong (external link)
• Borrowed Moment (blog) (external link)
Life is uncertain. Eat dessert first.
Bob ­ D.
May 26, 2008 07:58 as a reply to  @ Rudi's post |  #3
Just to show how inconsistent the older Vivitar flashes can be, I just tested my 283 and 285.
The 285 is one I have owned since the early 1980s.
The serial number is 4095387 and it was made in Japan.
It has always operated without problem and never been sent in for repair.
The mean trigger voltage measured 7.1 VDC.
The highest recorded (of three measurements) was 7.3 VDC
The 283 I have also owned since the early 1980s.
The serial number is 1874358 and it was made in Japan.
The mean trigger voltage measured 261 VDC.
The highest recorded (of three measurements) was 263 VDC
Don't take my measurements as representative of all 283s or 285s; that is my point and the reason for this post; they vary widely.
I am no stranger to taking voltage measurements, it's something I do regularly in my work many times a week, and my DMM while not lab quality is not $20 junk meter.
Curtis ­ N
Master Flasher
May 26, 2008 08:05 |  #4
Test the trigger voltage before mounting it on your camera. It needs to be under 250v.
PaulBradley
May 26, 2008 08:06 |  #5
Yes, as other people have said if you attach a flash with a high trigger voltage you could kill your camera - be careful.
That only goes for triggering from the hotshoe though - if you trigger with pocket wizards, ebay triggers or a PC cord it would be fine.
As you said, you'll get no TTL, but that may not be a disadvantage depending on intended use.
By the way, google "Strobist", "lighting 101" and "lighting 102" for good info on using manual flashes off camera.
Paul
E-K
May 26, 2008 08:19 |  #6
PaulBradley wrote in post #5597621 (external link)
PC cord has the same limitation as the the hot shoe in most cases which as Curtis indicated should be 250V for the 30D; unofficially. Officially I think Canon only wants you to use Canon flashes ;).
e-k
sacral
May 26, 2008 14:37 |  #7
Hah thanks for all the great info everyone! There is probably a collective millenium or more of photography experience/information here. LOVE IT!
1,550 views & 0 likes for this thread, 6 members have posted to it.
2904 guests, 177 members online
