Any input would be appreciated. 2nd shoot day with new 40D out at disneyland.
Cisko213 Member 66 posts Joined May 2008 More info | May 25, 2008 23:33 | #1 Any input would be appreciated. 2nd shoot day with new 40D out at disneyland. Canon 40D, 17-85mm and 70-300 Canon lenses. Lens hoods for both. 430ex flash and a Lowepro sling bag.
Anke "that rump shot is just adorable" UK SE Photographer of the Year 2009 30,454 posts Likes: 3 Joined Oct 2006 Location: Royal Tunbridge Wells, UK More info | May 25, 2008 23:35 | #2 Blimey, hummers in DisneyLand?! Anke
May 25, 2008 23:36 | #3 Of course I croped the 2nd shot. Canon 40D, 17-85mm and 70-300 Canon lenses. Lens hoods for both. 430ex flash and a Lowepro sling bag.
BARBIE Member 147 posts Joined Jun 2005 Location: COSTA MESA More info |
Anke "that rump shot is just adorable" UK SE Photographer of the Year 2009 30,454 posts Likes: 3 Joined Oct 2006 Location: Royal Tunbridge Wells, UK More info | May 26, 2008 01:15 | #5 BARBIE wrote in post #5596374 Good for you I just got my 40d, here is a test shot with no pp with a 28-75 tammy 2.8 Awww, cute cat! Can you post the EXIF on this one as it appears out of focus, possibly due to camera shake/low shutter speed. What shutter speed did you use? Anke
Anke "that rump shot is just adorable" UK SE Photographer of the Year 2009 30,454 posts Likes: 3 Joined Oct 2006 Location: Royal Tunbridge Wells, UK More info | May 26, 2008 01:16 | #6 One point of interest for the OP is to read up on the "Rule of Thirds". A really useful rule to bear in mind when composing shots. Anke
Andy_Cam Senior Member 385 posts Joined Jan 2008 Location: Netherlands More info | May 26, 2008 01:21 | #7 Anke wrote in post #5596599 What shutter speed did you use? The exif says 1/15 which would explain it.
Anke "that rump shot is just adorable" UK SE Photographer of the Year 2009 30,454 posts Likes: 3 Joined Oct 2006 Location: Royal Tunbridge Wells, UK More info | May 26, 2008 01:25 | #8 Andy_Cam wrote in post #5596610 The exif says 1/15 which would explain it. Yep it would. Barbie, as a rule of thumb the shutter speed should be equal to or faster than the focal length x 1.6 (the crop factor of your 40D). Anke
BARBIE Member 147 posts Joined Jun 2005 Location: COSTA MESA More info | The shutter was 1/15 at f/2.8 You're right the shutter speed is to low. I shot it on P. Should I have used tv or manual? I got to play around with it more It is still new to me. 40D Finally
Rafromak Goldmember 1,967 posts Joined Dec 2005 Location: Alaska More info | May 27, 2008 01:41 | #10 BARBIE wrote in post #5602768 The shutter was 1/15 at f/2.8 You're right the shutter speed is to low. I shot it on P. Should I have used tv or manual? I got to play around with it more It is still new to me. You could always take a few pictures with it on full auto, look at the photos you like the most (the most accurate, etc.), see what setting the camera used, and then try to duplicate the same settings, but with the camera on M or something like that. Also, I could be wrong, but you may be able to see the aperture and shutter speed right in the viewfinder just before taking the photo (on P mode). If the shutter speed is so low, you can at least use the flash or change the camera to another mode. Just go to the same room, with the same lighting conditions, set the camera to P mode, press the shutter button half-way, and see what camera shows you relating to shutter speed, etc.. Then switch to another mode, and repeat the steps. That will tell you at least one of the differences between one mode and the next. You will find at least one where the shutter speed has a priority, while another may have the lens aperture as a priority. 7D, 5DII
BARBIE Member 147 posts Joined Jun 2005 Location: COSTA MESA More info | I didn't use flash for the image, I was pretty close to the subject I didn't want to wash out the image. But I got to Play around with exposure more. 40D Finally
| Latest registered member was a spammer, and banned as such! 2797 guests, 173 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
