On a hazy sunny day any tips for correctly setting camera and flash?
I know the Auto mode will calculate it but would prefer tips to set it with one of the 'creative' modes...
mergino Member 93 posts Joined Jan 2005 More info | May 26, 2008 06:15 | #1 On a hazy sunny day any tips for correctly setting camera and flash?
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | May 26, 2008 06:52 | #2 In M meter and set for the ambient. Unless you have a flash with High Speed Sync, keep shutter speed at 250 or less. Adjust FEC for the amount of fill. Elie / אלי
DougPardee Senior Member 838 posts Joined Feb 2007 Location: Southern California, USA More info | May 26, 2008 09:03 | #3 The easy way is to use P mode. If you want more than that, prepare to spend some time learning about flash photography. It's surprisingly complicated: you have to deal with multiple light sources where one or more of the light sources aren't lighting the subject during metering and instead are controlled by the camera.
yogestee "my posts can be a little colourful" More info | May 26, 2008 09:55 | #4 tzalman wrote in post #5597367 In M meter and set for the ambient. Unless you have a flash with High Speed Sync, keep shutter speed at 250 or less. Adjust FEC for the amount of fill. What tzalman said..Meter for the subject in Manual then set your flash exposure at - 1 1/2 to - 2 stops.. Jurgen
PhotosGuy Cream of the Crop, R.I.P. More info | May 26, 2008 10:41 | #5 Most of these are without fill light: Angeline outdoors FrankC - 20D, RAW, Manual everything...
| Latest registered member was a spammer, and banned as such! 2863 guests, 167 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
